Raspberry Pi Forum FTDI USB-to-serial issue with NAK packets
  • Subscribers 706 subscribers
  • Views 697 views
Drew has a blog post about the FTDI USB-to-serial converter:
http://www.element14.com/community/groups/raspberry-pi/blog/2012/07/18/look-ma-no-display-using-the-raspberry-pi-serial-console
Apparently there is an issue with excessive interrups from NAK packets:
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=7866&start=111
http://www.raspberrypi.org/phpBB3/viewtopic.php?f=28&t=7866&start=114
  • fustini
    fustini over 13 years ago
    Interesting thread.  I've not had any trouble using FTDI cable for console access on the Pi, but it is acting as a USB device connected to my laptop.  I think the person reporting the problem must have been using FTDI cable connected to a Pi USB host port.
    I found the commands in the thread interesting:
    pi@raspberrypi ~ $ cat /boot/cmdline.txt
    dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait
    pi@raspberrypi ~ $ cat /proc/interrupts
               CPU0
      3:     842516   ARMCTRL  BCM2708 Timer Tick
    52:          0   ARMCTRL  BCM2708 GPIO catchall handler
    65:          2   ARMCTRL  ARM Mailbox IRQ
    66:          1   ARMCTRL  VCHIQ doorbell
    75:   65568338   ARMCTRL  dwc_otg, dwc_otg_hcd:usb1
    77:       8312   ARMCTRL  bcm2708_sdhci (dma)
    79:        338   ARMCTRL  bcm2708_i2c.0, bcm2708_i2c.1
    80:          0   ARMCTRL  bcm2708_spi.0
    83:      47024   ARMCTRL  uart-pl011
    84:      18082   ARMCTRL  mmc0
    Err:          0
    pi@raspberrypi ~ $  sh -c "cat /proc/interrupts | grep dwc && sleep 10 && cat /proc/interrupts | grep dwc" | awk '{ if (s==0) s=$2 } END { print ($2-s)/10 }'
    8035.9
    So this would seem to confirm that USB controller causes 8,000 interrupts a sec.
    e14 Contributor over 13 years ago in reply to fustini
    I am unsure how old previous report is, but the cmdline.txt isn't having the latest patches enabled that reduce the interrupt rate.
    The patch isn't really reducing the actual interrupt rate, it's just handling some interrupts that have no interesting usb data in a short assembly routine that just acknowledges the interrupt if I understand things well.
    So, if you have a device like an ftdi connected, interrupt range will go up again, but probably only when you start to use the device.
