Raspberry Pi Forum Tiny Touch Screen for Pi
  • Subscribers 706 subscribers
  • Views 848 views
  • touch_screen
the-dubster
the-dubster over 13 years ago
1st post - and I ask an awkward question! image
Does anyone know the interfacing for the iPod nano screen and digitiser - and is it compatible with the DSI input on the Pi?
The reason I ask is I plan (I always 'plan', sometimes I even 'execute'), to build a Car computer with my Pi.
Not the usual 'run-of-the-mill' media centre, but a full replacement dashboard.
As I don't have OBD (or even an ECU) I will be needing a Gertboard for sensor inputs (Speedo, Revs, Fuel Temp) and Dash warning lights. The intention is to drive graphical representations of the existing analogue gauges, and warning lights could be replaced by text prompts. (More on that in later posts). image
Where the mini touch screen comes into play is for starting/stopping the car.
The idea is the provide a 'Start Button' graphic when the Pi detects an input from the RFID reader I have (logic state change) and then pressing the touchscreen starts the car, on detecting that the engine is running the graphic then changes to a 'Stop Button' graphic - and you can probably guess what happens when you touch that.
Basically, I want to use a pretty display instead of a really easy, cheap, already provided on the Gertboard as a buffered input, button!! - Sorry!! image
Any ideas? (Other than 'just use a damned button you fool')!!
Andy
  • wallarug
    wallarug over 13 years ago
    Maybe,
    One thing to look at is if the connectors on the display correspond with what the BCM wants.  If not, then the answer is probably no.  (From my knowledge and reading).
  • the-dubster
    the-dubster over 13 years ago in reply to wallarug
    The connectors unfortunately are what the Nano wants . . . . . . . if there is info regarding the pinouts/signals etc - and they are compatible - then I can connect those together irrespective of plugs/connectors incompatability.
    I have big hammers, insulation tape and a welder . . . . . . . . . . . . image
  • jason721
    jason721 over 13 years ago
    It would probably be worth while to check out the LCD Touch Screen Thread on the RPF page. The have discussed iPhone/iPod Touch screens if it hasn't been discussed about the Nano screens someone there might know the aswers.
    http://www.raspberrypi.org/phpBB3/viewtopic.php?f=9&t=2425&start=25
  • the-dubster
    the-dubster over 13 years ago in reply to jason721
    @Jason G
    Thanks for that Jason, time to bother another bunch . . . . . .
    Reading the thread does seem promising though.
    Regards
  • the-dubster
    the-dubster over 10 years ago
    http://www.element14.com/community/docs/DOC-77883?ICID=rpiaccsy-featured-products
    Who said prayers never get answered . . . . . . image
