Raspberry Pi Forum Non-USB WiFi options
  • Replies 9 replies
  • Subscribers 708 subscribers
  • Views 1192 views
AniGeek
AniGeek over 13 years ago
i had a quick question. is it possible to make it to where the raspberry pi can use wifi without using a wifi dongle is there like a pcb or dev board that can be connected to save the usb port for other connectables.
    The general way is to use a powered USB hub so you can get more USB ports with sufficient power, and then plug your USB Wi-Fi dongle into the hub.
  • AniGeek
    AniGeek over 13 years ago in reply to e14 Contributor
    well yes but im trying to avoid using a dongle but want the wifi internal of the case ill be building
  • fustini
    fustini over 13 years ago in reply to AniGeek
    It's possible to use a SPI or UART (serial) WiFi module which you might find used in a microcontroller project.  However, you would then loose the native networking capabilities of Linux.  If compactness is your goal, then you might want to look at a small USB WiFi adapter like the Asus USB-N10 (40T547440T5474).
  • AniGeek
    AniGeek over 13 years ago in reply to fustini
    would you be able to go into more detail mr fustini of how linux would lose its native networking capabilities. i only know how to use linux i dont know too deep anymore on advanced stuff on linux.
  • fustini
    Sure, so with microcontroller boards like the Arduino I've used a couple different WiFi modules similar to:
    http://www.microchip.com/wwwproducts/Devices.aspx?dDocName=en548015
    https://www.sparkfun.com/products/10822
    https://www.sparkfun.com/products/11049
    The external microcontroller communicates with the WiFi module via a simple serial protocol (either standard serial, e.g. UART, or SPI).  These modules could be connected to the Raspberry Pi via it's GPIO pins (UART or SPI depending on the module).  But the module won't appear as a network interface like the Ethernet port or a USB WiFi "dongle" would.
    Instead, a program would have to be written to run on the Pi and communicate with the WiFi module to tell it do things like connect to remote server, send requests and receive responses.  If you just want to grab specific data from a simple web page or RSS feed, then this is doable.  But you won't be able to use a simple serial WiFi module to browse the web or run a server like Apache.
    Cheers,
    Drew
  • wallarug
    wallarug over 13 years ago
    You are aware that this could get messy software wise if you don't know what your doing?
    Here's a couple of alternative suggestions:
    plug one of these into the ethernet port on the Pi  http://www.netgear.com/landing/wnce2001.aspx if you want it inside the box then you'll just need a bigger box!
    However it would free up a usb port and as it's effectively transparent there's nothing to be done on the Pi which just thinks it has a normal wired ethernet connection.
    RN171XVS-I/RM - MODULE, WIFI, 802.15.4 DROP-IN W/ANTRN171XVS-I/RM - MODULE, WIFI, 802.15.4 DROP-IN W/ANT or similar embedded module, downside is that they tend to be slow as you're talking to them via a serial port and there's no linux driver, so you have to do it all yourself.
    Software wise, and depending on what's at the other side, it could be possible to run a ppp session over the serial port to a remote endpoint and treat it much like an old dial-up modem - that would give you a way to use it within the normal linux networking stack.  But there's a lot of details you'd need to work out in order to get that working.
  • AniGeek
    AniGeek over 13 years ago in reply to wallarug
    yesb i do understand this. but i have always learned by testing things so i just figured id ask around and see what my options were.
  • AniGeek
    ty for the info. ill see what i can figure out
