Raspberry Pi Forum RPi.GPIO input problem
  • Subscribers 707 subscribers
  • Views 582 views
cityswift
cityswift over 13 years ago
Hi I have got the gpio inputs and outputs working using the echo commands in Linux but when I try the RPi.GPIO module with Python as detailed on the Python website pypi.python I can work the ouput ok but am not able to read the inputs.  When I enter the " input_value = GPIO.input(7) " line nothing happens. Has anyone made this work? If so I would appreciate some help. Thanks image
    Howdy,
    What do you mean nothing happens?
    The statement:
    Sets the variable "input_value" to True or False depending on whether there is voltage on the input pin (assuming you've set it up correctly).  There will be no text returned when you do this.  You can see the value with:
    >>> print input_value
    This will print the Boolean value (True or False), which you can use to control the logic of your Python program.
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    watch this: http://www.raspberrypi.org/archives/1417
    I found this very helpful when first using RPi.GPIO.
  • cityswift
    cityswift over 13 years ago in reply to wallarug
    Thanks for your replies - problem sorted - I am new to Python and the syntax is a little confusing - I was using = where it should have been ==! imageimage
