Raspberry Pi Forum Python: separate variables after sending through TCP.
  • Replies 8 replies
  • Subscribers 678 subscribers
  • Views 760 views
wallarug
wallarug over 13 years ago
I have set-up a python TCP server and client.  I send the data using the following commands:
[code]
def send2screen(motor_a,motor_b):
    byte4 = chr(int(motor_a))
    byte5 = chr(int(motor_b))
    sock2.sendall(byte4+byte5)
< Other stuff goes here >
[/code]
When the data gets to the Server, I want to be able to separate the two variables motor_a and motor_b.  The two variables hold a value that is constantly changing between 0 - 255 for each variable. eg. Motor_a = 64, motor_b = 117
Is there anyway that I can separate this information?
This is where the data will need to end up:
[code]
lcd.clear()
   ipaddr = run_cmd(cmd)
   lcd.message('A = ' +int(motor_a) ' | B = ' +int(motor_b) '/n')
   lcd.message('IP %s' % ( ipaddr ) )
[/code]
Any help will be necessary.
  • wallarug
    I still have not completed this and would still like help from anyone who knows what they are doing.
  • mgt6910
    mgt6910 over 13 years ago in reply to wallarug
    Hi Fergus,
    I'm a python newbie like you, but I decided that I needed to know how to solve your problem, so I did some research to arrive at the code that follows. I hope
    that it helps you.
    motor_a= 66
    motor_b= 117  # for example...
    Send_String=str(motor_a)+"    "+str(motor_b)     # make a string to send,using 3 spaces to separate the 2 values
    print "the send-string is ("+Send_String+")"
    # Send the string.
    Received_string=Send_String
    #At the receiving side, decode
    # the motor values by :....
    motor_a=int(Received_string[:4])
    motor_b=int(Received_string[5:])
    print"motor_a= "+str(motor_a)
    print"motor_b= "+str(motor_b)
  • wallarug
    wallarug over 13 years ago in reply to mgt6910
    Malcolm Turner wrote:
    Hi Fergus,
    that it helps you.
    motor_a= 66
    # Send the string.
    Could you please include a full sample of python script please?
    Former Member over 13 years ago in reply to wallarug
    a='x'
    b='y'
    c=a+b
    d=c[0]
    e=c[1]
    print d
    print e
    output:
    y
  • wallarug
    wallarug over 13 years ago in reply to Former Member
    That doesn't work on the other side of the connection.  I get the information buffering and then when I ask it to print on my LCD display, it just prints out too many digits to fit on the screen instead of the latest value recieved.
  • mgt6910
    mgt6910 over 13 years ago in reply to mgt6910
    Hi Fergus, I'm not the person to advise you on socket-programmimg, but I tested my script
    with ranges of values, and it solves the character-handling part.
    Good luck with this project.
    Malcolm
  • mgt6910
    str(motor_a) will have a maximum of 3 digits if the values were limited to 255 on
    the sending side.   Enjoy the debugging !
  • wallarug
    Thanks for your help, I will test when I find some time.
