Hi, I'm looking for some cheap raspberry pi cases but don't know which website to trust. I live in belgium.
If you're good with a Dremel tool or equivalent, Craig French has managed to fit a RasPi into an Altoids tin/box. He has links to photos.
I'll let others make their own recommendations. I use an open-frame vertical mount which provides natural convection cooling for both sides of the board. I have a rev 1.0 RasPi so the LAN9512 gets pretty warm otherwise.
Hi Ather
I bought one of these: http://www.amazon.co.uk/Raspberry-PI-Box-Transparent-Clear/dp/B008TCUXLW/ref=sr_1_2?ie=UTF8&qid=1355319176&sr=8-2
and also one of these: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=390510265507
Very pleased with both and prefer them over the more expensive one that I have for my 3rd pi.
Steve
Here are a few cases
https://www.adafruit.com/products/859
https://www.adafruit.com/products/975
https://www.adafruit.com/products/1067
https://www.adafruit.com/products/1039
https://www.adafruit.com/products/1123
https://www.adafruit.com/products/1124
https://www.adafruit.com/products/1122
and
http://ru.farnell.com/multicomp/mc-rp001-wht/enclosure-raspberry-pi-white/dp/2113797
http://ru.farnell.com/multicomp/mc-rp001-blk/enclosure-raspberry-pi-black/dp/2113798
I tested out one of our Multicomp cases and it did the job well - it's transparent rather than tinted like it looks in the picture:
http://be.farnell.com/multicomp/mc-rp001-clr/enclosure-raspberry-pi-clear/dp/2113799
It also comes in black and white.
Hello Ather, if you are seeking a good quality case without the need for modifications then you need to see these: http://shop-cyntech-co-uk.myshopify.com/collections/all in the USA, you can view the same cases at: http://shop-cyntechgroup-com/myshopify.com/collections/all
These are well built and come in four colors. They use superior plastic than others - no fracturing or cracking when putting them together.
The clear case Steve Read is reffering to is great.
This Case works great and looks great. Strong as well as attracts attention.
But Amazon will not export these cases to Europe, don't know about the rest of the world.
