Raspberry Pi Forum Home automation using Raspberry pi
  • Subscribers 706 subscribers
  • Views 621 views
hi to all,
I want to make home automation using raspberry pi
I want to control, different instruments through monitor attached to the rasp pi.
My problem is, how to make a controlling screen? through which software?
how?
  • wallarug
    wallarug over 13 years ago
    a good program to use is 'screen'.
    to install:
    apt-get install screen
    I can't tell you the specifics of installing the software but you can research how to use this software.
    another program to control screens in tightVNC.  This will only work if you have a raspberry pi attached.
  • GreenYamo
    GreenYamo over 13 years ago
    Hello Parag
    For automation, have a look here: http://www.raspberrypi.org/phpBB3/viewforum.php?f=37
    With regards to screens, as Fergus says you can use something like VNC if you want to view the pi remotely. Alternatively you could use an cheap composite screen from Amazon or ebay (around £20) if you wanted something direct to the Pi, or even a 16x2 or 20x4 LCD.
    Steve
