Raspberry Pi Forum how to access...
  • Replies 9 replies
  • Subscribers 708 subscribers
  • Views 1239 views
how to access...
rhydian98
rhydian98 over 13 years ago
Hello
I have just got my raspberry pi and was wondering how would i be able to access the things that i apt get
  • wallarug
    wallarug over 13 years ago
    depends what it is that you are downloading.  Some things are part of the Graphical User Interface (GUI) and can only be accessed by logging into a graphical session using: 'startx' command.
    Others are accesses by simply typeing in the name of the program.  For Example:
    omxplayer -o hdmi file.mp4
    will load up 'file.mp4' and play the file.  other examples include:
    minicom /dev/ttyAMA0
    ...Which will load a serial command prompt session on device '/dev/ttyAMA0'.
    Most of the time you can just google how to use the program you have just installed.  Otherwise try typing the program name and -?:
    program -?
    ...for help.
    Hope this is what you meant and hope this works for you.
  • rhydian98
    rhydian98 over 13 years ago in reply to wallarug
    I am trying to access perl but I cannot find how to find it so if you could tell me what the code is
  • wallarug
    wallarug over 13 years ago in reply to rhydian98
    I thought Perl was just a language not a program?
  • mconners
    mconners over 13 years ago in reply to rhydian98
    assuming the install went ok, it should be in /usr/bin/
    you can type
    which perl
    which should give you the path if it finds it
    Mike
  • mconners
    mconners over 13 years ago in reply to wallarug
    perl is a language, but the interpreter is a program, not unlike python.
    Normally in a perl script (or sh, or csh, etc for that matter) you can put
    #!/usr/bin/perl (or #!/bin/sh , or whatever, at least on *nix systems)
    and once you change the execute bits using chmod, you can run the program just by typing the name, just like an exe, the executing shell will call the perl interpreter
    this achieves the same thing as typing
    perl myFile.pl
    but saves you from typing the first 5 characters
    the same thing works on python as well, but you need to know the path to the intepreter.
    Mike
  • mconners
    mconners over 13 years ago in reply to mconners
    one other thing, if you knew the path to the perl interpreter, and expected to run your script in the local directory and it gives you a file not found error, it may be that the current path (.)
    is not in your path, you may have to type
    ./myFile.pl to get it to run.
    Mike
    Perl should have been already installed by default, at least in Raspbian.
    One other thing to note is that if you put a bin directory in your home directory (~/bin), the next time you login, that will automatically be in your $PATH, at least in the console (~/.profile does that).  Then as long as you are in the text console, have the proper shebang line as the first line of the Perl script (#!/usr/bin/perl as mentioned by Michael), and the script has execute permission, you can simply type the name of the script to run it.
    However, for some reason when you startx, it seems to use a default $PATH instead of the one .profile sets during login, so your personal bin may be missing from your $PATH in lxterminal.
  • rhydian98
    the /usr/bin/perl does not work and i cannot get the execution to work
  • mconners
    Alright, you have to give us more info
    if you type
    which perl
    what do you get?
    Mike
