Raspberry Pi Forum PiFace Problems
  • Replies 78 replies
  • Subscribers 717 subscribers
  • Views 12303 views
  • piface
  • raspberry_pi_accessories
PiFace Problems
keithtowns
keithtowns over 13 years ago
Am I missing something? I have two PiFace and 3 Raspberry Pi. I followed the instructions the get the PiFace working but have yet to succeed. I have tried the image provided as well as updating an existing Raspian image to no avail. I have also tried all my Pi and the two PiFace in all the combinations. I almost gave up but also tried a different power supply and SD card. None of the above got the emulator to switch on the LEDs and I could not do it through Python. Any ideas? I've spent hours on this, please tell me I've missed something. Thanks.
  • imac
    imac over 13 years ago in reply to e14 Contributor
    Hi
    Not sure if appropriate but I downloaded new version of  WHEEZY came out dated 9th Feb and found that it fixed a few of the problems I had.
    Its hard keeping up with these updates.
    Feel the whole of the Raspberry Pi project suffers from this.
    Are you sure you are using the latest version of Raspbian?
    Also, have you tried updating the firmware on your Raspberry Pi? Follow the instructions here: https://github.com/Hexxeh/rpi-update
    modprobe translates the hypen to an underscore, I think. So it doesn't matter which.
    sudo apt-get upgrade seems to have done the trick!
    I didn't do the rpi-update but I will the next time I run into a mystery.
    Thank you so much, Thomas and everyone on this list!
  • keithtowns
    keithtowns over 13 years ago in reply to e14 Contributor
    Hi Thomas
    Many thanks for your posts. I have to put aside a day to do this so I'll let you know how I get on. My target is to get the PiFace working so my daughter can program it through Scratch to control a set of traffic lights (3 LEDs) when a Matchbox car approaches (reed switch and magnet on the car).
    But I've got to get it going first!
    Cheers
    Keith
  • keithtowns
    keithtowns over 13 years ago in reply to keithtowns
    Hello All
    I have just spent my Sunday morning trying to get this working again.
    Using 512Mb Pi and Transcend 8Gb SD card:
    1. Downloaded latest Raspian 2013-02-09-wheezy-raspbian
    2. Updated Firmware https://github.com/Hexxeh/rpi-update
    3. Followed instructions in http://www.element14.com/community/servlet/JiveServlet/previewBody/53057-102-1-267727/PiFaceDigital_Get_Started_140213v1.pdf
    4. Did another sudo apt-get update && sudo apt-get upgrade
    When I run the emulator it can see the PiFace but no LED's or relays change.
    This is not getting my daughter very interested in computing.
    Any help will be really apreciated.
    Keith
    e14 Contributor over 13 years ago in reply to keithtowns
    Hi Keith,
    Does the board work when just using Python? Try opening a Python shell and talking to PiFace:
        $ python
        >>> import piface.pfio as p
        >>> p.init()
        >>> p.digital_write(1, 1)
    What error does that produce?
  • mrbuzzcut
    mrbuzzcut over 13 years ago in reply to e14 Contributor
    Maybe a little late, but I fixed the spi permission issue by adding myself to the spiuser group.
  • keithtowns
    Hi Thomas
    I tried your code in a Python shell from a LXTerminal and from Python 2.7.3 Shell.
    No errors were reported when I typed in each of the lines but I guess this was going to switch on an LED or relay? Neither happened.
    Thanks for your help so far.
    Keith
  • dgmcneil
    dgmcneil over 13 years ago in reply to keithtowns
    Hi Keith, did you ever get you PiFace to work?
    I spent two days struggling with this.  I found it hard to find documentation and I could have saved myself two days of trouble-shooting had I just had access to a schematic.
    My PiFace was shipped without a jumper on JP7.  The absence of JP7 disables the 5 V rail for the outputs so there was no lights, no relay click.  Adding JP7 made the PiFace work as advertised.
    While I'm typing I may as well add that I'm disappointed that the designer of the PiFace didn't make the unused IO ports on the Raspberry Pi available on the board.  This limits what would have otherwise been a very nice addition to the Pi.
    Dave
  • keithtowns
    keithtowns over 13 years ago in reply to dgmcneil
    Hi Dave
    No my PiFace is still not working and both of them have a jumper 7 installed.
    Thanks anyway
    Keith
