Raspberry Pi Forum PiFace Problems
  • Replies 78 replies
  • Subscribers 717 subscribers
  • Views 12381 views
  • piface
  • raspberry_pi_accessories
PiFace Problems
keithtowns
keithtowns over 13 years ago
Am I missing something? I have two PiFace and 3 Raspberry Pi. I followed the instructions the get the PiFace working but have yet to succeed. I have tried the image provided as well as updating an existing Raspian image to no avail. I have also tried all my Pi and the two PiFace in all the combinations. I almost gave up but also tried a different power supply and SD card. None of the above got the emulator to switch on the LEDs and I could not do it through Python. Any ideas? I've spent hours on this, please tell me I've missed something. Thanks.
    hello,
    I ma having issues with my piface digital.
    My Rasbian is upto date.
    Installed the piface libraries & emulator as per following PiFace – Install PiFace Digital Software – Updating Raspbian
    however when I run the python3 /usr/share/doc/python3-pifacedigitalio/examples/blink.py
    I get following error;
    Traceback (most recent call last):
      File "/usr/share/doc/python3-pifacedigitalio/examples/blink.py", line 9, in <module>
        pifacedigital = pifacedigitalio.PiFaceDigital()
      File "/usr/lib/python3/dist-packages/pifacedigitalio/core.py", line 82, in __init__
        self.init_board()
      File "/usr/lib/python3/dist-packages/pifacedigitalio/core.py", line 107, in init_board
        h=self.hardware_addr, b=self.bus, c=self.chip_select))
    pifacedigitalio.core.NoPiFaceDigitalDetectedError: No PiFace Digital board detected (hardware_addr=0, bus=0, chip_select=0).
    I have checked using ls -l /dev/spi* command and I get following
    pi@raspberrypi /usr/local/bin $ ls -l /dev/spi*
    crw-rw---T 1 root spi 153, 0 Jan  1  1970 /dev/spidev0.0
    crw-rw---T 1 root spi 153, 1 Jan  1  1970 /dev/spidev0.1
    python version is
    pi@raspberrypi /usr/local/bin $ python
    Python 2.7.3 (default, Mar 18 2014, 05:13:23)
    [GCC 4.6.3] on linux2
    Type "help", "copyright", "credits" or "license" for more information.
    am I  missing something. please help me out.
  • rbladd
    rbladd over 12 years ago in reply to e14 Contributor
    Did you try sudo before  Python3 as many functions require root user.
    e14 Contributor over 12 years ago in reply to rbladd
    Yes I did try with sudo however still getting same msg
  • joman
    joman over 8 years ago
    The PiFace Digital 2 documentation is almost non-existent. You can't install it using the instructions. It does not work with Raspbian Stretch and you can't download earlier versions of raspbian. Element14 should address this problem or STOP SELLING PRODUCTS THAT DO NOT WORK!
    Your best bet is buy something else that actually works. The support from Element14 is terrible and they should be ashamed of themselves.
  • beacon_dave
    beacon_dave over 8 years ago in reply to joman
    Are you sure about that second part ?
    Index of /raspbian/images
    Index of /NOOBS/images
  • joman
    joman over 8 years ago in reply to beacon_dave
    Yes.
    Neil Hastings
  • gadget.iom
    gadget.iom over 8 years ago in reply to joman
    ...well evidence would suggest otherwise.
  • oldcoder
    oldcoder over 8 years ago in reply to joman
    You are so right. I have gone through two PiFace boards and could get neither to work either on a B+ or a 3. The only support available is the basic setup that didn't work in the first place/
    You can't expect a hobbyist community to produce the support but you CAN expect those who prfit from it to.
    Fix PiFace or stop selling it.
