Raspberry Pi Forum PiFace Problems
  • Replies 78 replies
  • Subscribers 717 subscribers
  • Views 12373 views
  • piface
  • raspberry_pi_accessories
PiFace Problems
keithtowns
keithtowns over 13 years ago
Am I missing something? I have two PiFace and 3 Raspberry Pi. I followed the instructions the get the PiFace working but have yet to succeed. I have tried the image provided as well as updating an existing Raspian image to no avail. I have also tried all my Pi and the two PiFace in all the combinations. I almost gave up but also tried a different power supply and SD card. None of the above got the emulator to switch on the LEDs and I could not do it through Python. Any ideas? I've spent hours on this, please tell me I've missed something. Thanks.
    image yeah! That's it. Hours that I have employed you and then such an error.. big thanks!
  • videogame95
    videogame95 over 12 years ago in reply to e14 Contributor
    Hi i have a piface all the pins light up on override 1-7
    The piface will not recognized import piface.pfio as pfio
    most programmes i have run come up with syntex error
    i conected a door closer to the pin ligths up it works but relay does not swiitch
    i will do fresh install piface already loaded but it has no wifi installed
    any help with this it sounds a bit the same as yours
    e14 Contributor over 12 years ago in reply to videogame95
    Are you using the most up-to-date libraries? You can install them with:
    $ sudo apt-get update && sudo apt-get install python{,3}-pifacedigitalio
    Examples on how to use pifacedigitalio can be found here: http://piface.github.io/pifacedigitalio/example.html
    Hi Thomas,
    I've been trying to get my piFace working.  I've been able to download and launch the piface-emulator.  Works fine.
    However I'm trying to run a simple python program.  I think it's a sample but I renamed it a couple of days ago and forget which it is.
    from time import sleep
    pfio.init()
    while(True):
        pfio.digital_write(0,1) #turn on
        sleep(1)
        pfio.digital_write(0,0) #turn off
        sleep(1)
    I got a strange syntax error in pfio when I ran this from IDLE:
        print "%s %s" % (__pfio_print_PREFIX, text)    <--- this errors out as a syntax error
        print("{0} {1}").format(__pfio_print_PREFIX, text)  <--- I modified it to ths and it seems to accept the line
    Getting past that error I now get:
    Traceback (most recent call last):
      File "/home/pi/piface/python/myPiface.py", line 2, in <module>
      File "/home/pi/piface/python/piface/pfio.py", line 13, in <module>
        import spi
    ImportError: No module named spi
    So, I'm missing something but, due to my ignorance of Linux I'm at a loss.  Shouldn't spi be included in the distro? oris this somethimg more fundamental I should have.
    Thanks for any help...
    Lou
    YES!  Thanks Thomas, that worked.
    A quick question, in python, when I import a library, do I have to specify a directory or are all libraries centrally located?
    Thanks again for your help, now I can get started :-)
    Lou
    All Python modules are usually installed somewhere in /usr/lib/python* but Python will check all of the locations in sys.path. Here is some more info: http://docs.python.org/3.2/tutorial/modules.html#the-module-search-path
    Whoops, spoke too soon...
    Edit:
    I went back and tried to run my original program, still failed on spi  library.
    I simply modifed it to use pifacedigitalio and it came together so all is well.
    Is piface.pfio an older or somehow different library with the spi library performing some special communications?
    Again, thanks for your help and the url for the module-search-path.
    Lou
    pifacedigitalio is the new library. piface.pfio is the older (2012) library.
    You can find all of the official PiFace software here: https://github.com/piface
  • videogame95
    I have run the programme in idle and get back no module name piface pfio
    help please
    I am trying get on buttons working on my piface work in emulator over ride mode
    leds light up when press
    my buttons on my piface are no working?
