Raspberry Pi Forum Gertboard cable straps
  • Subscribers 705 subscribers
  • Views 628 views
Hello, I want to buy more cable straps for the Gertboard, searched element 14, no luck, where can I buy these, thanks.
    I would also like to purchase more straps.
    Your looking for Female to Female 1 pin DuPiont cables most places seem to classify them under Arduino supplies. Beware most packs a male to male.ie for bread board.
    The big problem is finding them short enough 20/30cm ones are quite common shorter not so much.
    You may want to make them your self using plug connector inserts (http://au.element14.com/te-connectivity-amp/2-167301-2/crimp-socket-tinned/dp/1187812?in_merch=true&MER=MER-L52-L5IB-PD-ACC-CNN). they are the sort you make push connecters with by soldering/crimping them on a wire them inserting into a plastic shell. just don't buy the shells and may be add a little heat shrink to insulate and firm up the connection .
    Have a lookj at this thread:
    http://www.raspberrypi.org/phpBB3/viewtopic.php?t=36212&p=306110
    Hi John,
    Check out CPC prototyping page we have lots of different combination of male female connectors in both 10pk and 40pk, we also offer free UK delivery image
    http://cpc.farnell.com/jsp/bespoke/bespoke7.jsp?bespokepage=cpc/en_CC/makerspace/pcb_prototyping.jsp
