Raspberry Pi Forum New kid on the block the pcDuino ...
  • Replies 56 replies
  • Subscribers 707 subscribers
  • Views 10374 views
jamodio
jamodio over 13 years ago
Yet another ARM Cortex board ... The pcDuino com ... getting one to see how compares with the Rpi ...
Atr least I didn't have to wake up in wee hours like a year ago to get one.
Cheers
Jorge
    e14 Contributor over 12 years ago in reply to jamodio
    jamodio in that screenshot of your wbquad, you seem to have ubuntu running at something more than 640x480.  Did you have to do anything to get the better resolution ?
    640x480 is the only choice I'm getting, and in any case unity with it's fixed size window is useless at that resolution since the OK button is off the screen so I couldn't click on it anyway.
    jamodio wrote:
    One more bit of information to share, the Wandboard afaik has not a single certification, I didn't do a detailed analysis but I'd venture to bet that if they try, it won't pass FCC Class B, not even close.
    On the other hand, the BBB is both CE and FCC certified (class B). You can even download the certificate of compliance https://github.com/CircuitCo/-BeagleBone-Black/blob/master/10238105EUS1.pdf?raw=true
    Interestingly the Cubieboard A10 appears to have recently passed FCC Class B, the certificate ant test report are available from their download page http://cubieboard.org/download/
    so it does seem that a proportion of the people building these dev boards do actually care about getting them compliance tested
  • jamodio
    jamodio over 12 years ago in reply to e14 Contributor
    Using the HDMI video interface I get 1280x720, but didn't spend much time trying to change it or testing other settings.
    That screen shot and how I've it since then working is via vnc with 1280x960 (vncserver :1 -geometry 1280x960)
    Regards
    Jorge
  • jamodio
    I've the Cuibieboard 1 and 2 (A20) on the queue to be tested, also purchased a pair of the breadboards. The also have now a new very interesting baseboard for both, thinking about adding it to Santa's list :-)
    Regards
    Jorge
    The only problem with the breadboard is that the VGA connector makes it a little difficult to change the uSD card. It's just slightly too close.
    Was that with a widescreen monitor ?  I wonder if it's because I'm using a 4:3 monitor, or just a different version of ubuntu...
