Raspberry Pi Forum What is a good USB audio input device for Raspberry Pi?
  • Subscribers 707 subscribers
  • Views 579 views
  • audio_processing
gervasi
gervasi over 13 years ago
I would like to use my Raspberry Pi to save audio and play it back.  Ideally I'd like to create a delay buffer so audio coming in is sampled and played back at a certain delay.  It seems like the the easiest way to do this is to get a USB audio input device that has a driver for Linux.  What I get to that point, though, where can I learn to write code that accesses data coming from that driver?
  • bbolo1
    bbolo1 over 13 years ago
    Basically, any USB device implementing Audio class would be good. You need to put the right settings into /etc/asound.conf file. When you plug the USB audio adapter it should be recognized by the RPI and you would be able to use a few apps that using the sound driver.
    As for some code examples you can try ALSA utilities and some other apps using the ALSA audio driver (e.g. mpg123, aplay, ...)
  • andrewk182
    andrewk182 over 13 years ago
    I myself would look on linux form's there are some great tutuor's and book's to download
    first:
    http://www.google.com/#hl=en&sugexp=les%3B&gs_rn=3&gs_ri=psy-ab&gs_mss=how%20to%20access%20usb%20a&qe=aG93IHRvIGFjY2VzcyB1c2IgYXVkaW8gaW5wdXQgZm9yIGxpbnV4&qesig=cnk2goJF2ZmEXpjcZmlTtg&pkc=AFgZ2tmTW4QaHvW7YvIdkE5U9zyhA9SIw-McOZkSdTnQ-JYETItSKTHiWrcW6gMcqLkqomcz5qsx2sA4OIr6W8HuXbmqllxEUw&pq=ups&cp=39&gs_id=ck&xhr=t&q=how+to+access+usb+audio+input+for+linux&es_nrs=true&pf=p&tbo=d&sclient=psy-ab&oq=how+to+access+usb+audio+input+for+linux&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&bvm=bv.42553238,d.dmQ&fp=ac0d81d0687ff531&biw=1135&bih=890
    second:
    http://www.google.com/#hl=en&sugexp=les%3B&gs_rn=3&gs_ri=psy-ab&gs_mss=how%20to%20write%20code%20toaccess%20usb%20audio%20input%20for%20linux&qe=aG93IHRvIHdyaXRlIGNvZGUgdG8gYWNjZXNzIHVzYiBhdWRpbyBpbnB1dCBmb3IgbGludXg&qesig=1OVt4z360vd27YVZyjZGrQ&pkc=AFgZ2tmTW4QaHvW7YvIdkE5U9zyhA9SIw-McOZkSdTnQ-JYETItSKTHiWrcW6gMcqLkqomcz5qsx2sA4OIr6W8HuXbmqllxEUw&pq=ups&cp=21&gs_id=e8&xhr=t&q=how+to+write+code+to+access+usb+audio+input+for+linux&es_nrs=true&pf=p&tbo=d&sclient=psy-ab&oq=how+to+write+code+to+access+usb+audio+input+for+linux&gs_l=&pbx=1&bav=on.2,or.r_gc.r_pw.r_cp.r_qf.&bvm=bv.42553238,d.dmQ&fp=ac0d81d0687ff531&biw=1135&bih=890
  • gervasi
    gervasi over 13 years ago in reply to andrewk182
    We got Syba SD-CM-UAUD working pretty easily.  image  I'm happy with it so far.
