Raspberry Pi Forum locate a working PSU for RasPi
  • Subscribers 675 subscribers
  • Views 426 views
  • power
Ive tried 3 PSU (Pwer Supply USB ) Plug in devices an though they say they are 1000Ma im still getting mo power
on my PI , so where can i get a guarenteed 100% out of the box power supply and Cable that works with the PI
Im using Ethernet , HDMI, USB Keyb Mouse / SD card , all required and that must be taken into consideration for
power requirmetns on startup ...
  • johnbeetem
    johnbeetem over 12 years ago
    If you're not getting the red PWR LED, then you may have a bad cable or a bad RasPi.  The RasPi Troubleshooting wiki has good sections on diagnosing Power/Start-up and Power Supply Problems.
    Former Member over 12 years ago in reply to johnbeetem
    im getting the red light syndrome which is either a SD Card issue or a Power Supply Issue as the SD is from a Kit supplied with the RPi and have used the correct program to install the Image ... my thoughts are its a Power issue for now
  • johnbeetem
    johnbeetem over 12 years ago in reply to Former Member
    I have heard of pre-programmed SD cards not working, though this may have been due to last fall's transition from 256MB to 512MB.  You might get some useful suggestions in this thread: New Raspberry Pi w/ 512mb - DOA?
