Raspberry Pi Forum how to download arduino on raspberry pi
  • Replies 16 replies
  • Subscribers 705 subscribers
  • Views 3303 views
chiversj
chiversj over 13 years ago
I followed the instructions from the book, titled Installing Arduino in Raspian. BIG FAIL. The word electronics did not show up. I have the latest download of Wheezy. Would appreciate some help on this. Thanks Jimmy
  • mconners
    mconners over 13 years ago
    I am not familiar with the book, but I did install the Arduino IDE on the pi and was able to communicate with the board. I assume the word "Electronics" you refer to is what you are expecting in a menu.
    Check to see if there is an arduino folder under /usr/share. It may be a link to arduino or could be arduino-1.0 or 1.1 whatever version you installed.
    Also you may have to reboot or log off/log back in to get it to show up in any of the menus.
    You can also type
    dpkg -l arduino
    to see if the package manager thinks it is installed.
    Good luck,
    Mike
    mcb1 over 13 years ago in reply to mconners
    Is this any help.?
    http://wyolum.com/projects/alamode/alamode-getting-started/
  • chiversj
    I checked user/share and there is NO Arduino folder. Also did dpkg -l arduino and that too was fail. So it looks like I need to download the file in order for it to work. Thank you for your help. JCC
  • mconners
    mconners over 13 years ago in reply to chiversj
    Just to be clear, that was /usr/share not /user/share but anyway,
    try doing
    sudo apt-get install arduino
    at the command  line and see if that gets you the result you want.
    Good luck,
    Mike
  • chiversj
    Mike that is where I started and I was looking for electronics in the menu and I never found it. I found a linux file for Arduino IDE on the Arduino home page/site and I am going to try and download it to the Rpi. Thanks JCC
  • chiversj
    Mike I hit a snag. Can you tell me how to download Arduino IDE to Pi. I have all the files on my PC but do not know which goes where. Thanks JCC
  • mconners
    You don't want to dl the stuff from the arduino site. That is going to be compiled for X86, not Arm, so it won't work on your machine.
    You may also need to dl arduino-core
    sudo apt-get install arduino-core
    I'm not near my pi at the moment, but I can look later and see if I can walk you through it.
    Mike
  • gdstew
    gdstew over 13 years ago
    Here's what I did to get the Arduino IDE on the Raspberry Pi:
    sudo apt-get update
    sudo apt get install arduino
    The update command will make sure that you get the latest versions of all the files. If you do not do this it may not find
    some of the files and it will not install. I've had this happen to me twice now.
    The install command will automatically download and install all the files needed  (including arduino-core) for the Arduino IDE.
    After you have have done this you should see the Electronics folder in your Applications menu. The Arduino IDE should be in
    that folder.
    Good luck.
  • chiversj
    chiversj over 13 years ago in reply to gdstew
    Mr Stewart Idid exactly that more than once and it did NOT work. Do not know why but the electronics folder does not come up. Thank you. Jimmy
  • gdstew
    gdstew over 13 years ago in reply to chiversj
    OK, let's try this, I know it looks like a lot but you will only need to do 1 or 2 (not both), and
      3 only if 1 or 2 fails:
    1) If you know how to use the vi editor:
      a. Make a backup copy first:
        sudo cp /etc/apt/sources.list /etc/apt/sources.list.bak
      b. Edit the file:
        sudo vi /etc/apt/sources.list
      c. Add this line:
        deb http://mirrordirector.raspbian.org/raspbian wheezy main contrib non-free rpi
      d. Try the apt-get update and install again.
    2) If you do not know how to use vi use a graphical interface editor by:
      a. Make a backup copy as shown in 1a
      b. Assuming you are in the pi home directory (/home/pi) so you know where the file is,
          copy the sources.list file:
        sudo cp /etc/apt/sources.list .
      c. Change the ownership so you can modify it:
        sudo chown pi:pi sources.list
      d. Use any text editor you like to add the same line as in 1c
      e. Put the modified file back where it belongs:
        sudo chown root:root sources.list
        sudo mv sources.list /etc/apt
       Note:  using chown again is probably not needed if sudo is used to move it back, but
                 just in case I added the command anyway.
      f. Try the atp-get update and install again.
    3) If 1 or 2 fails
    Do another apt-get install and send the error output and standard output from that command to
    the file arduino.txt using this command:
    sudo apt-get install arduino 2>&1 arduino.txt
    None of the normal text output from the command will be sent to the screen so just wait until the
    command line prompt is displayed before going to the next command.
    Change the ownership of arduino.txt to make sure you can read and write it:
    sudo chown pi:pi arduino.txt
    Attach the arduino.txt file to an email and send it to the email address in my profile.
    If there is an error message in the file I should be able to find it and help fix it.
