Raspberry Pi Forum Hynix RAM 512MB
  • Replies 7 replies
  • Subscribers 707 subscribers
  • Views 1049 views
Hynix RAM 512MB
One of the two RPi distributors is reporting that RPi's are being
returned due to problems booting, caused by some sort of
incompatibility between the Hynix RAM and an outdated OS.
http://www.raspberrypi.org/archives/3534
It isn't clear yet which distributor is using Hynix RAM,
or why it works differently from Samsung RAM, or how recent
the OS needs to be, or whether the fix is in the OS per se
or in the binary blob.
  • wallarug
    wallarug over 13 years ago
    Well... There is two ways to look at this situation.
    1.  Why are the distrubuters using a part that is affecting compadibility?
    2.  Why aren’t people updating their software with a new device?  Isn’t obvious that if you are running old software on a new device it (most likely) won’t work.  People should be getting a new image every time it is released anyway, especially with the state that the raspberry pi’s software is at the moment.  This is nothing different to people using a new computer - you must update your software!!!
  • GreenYamo
    GreenYamo over 13 years ago
    Thing is, I have seen a lot of problems in the forums where people had bought a package from either Farnellor CPC, Maplin etc that included a card with a pre-written image. My normal suggestion in these circumstances was to re-flash the card and pretty much all the time it worked again. I made the erroneous assumption that the post office must be nuking the cards somehow, but it would now appear to be for the reasons posted here.
    I can't imagine any of the big distributors constantly updating the bundled SD cards they are selling, and I think it is unfair to expect a person who has paid a premium for a card with an image on it, to have to go through that process themselves.
    I also am a little confused as to why a semi-incompatible part is being used.
    Steve
    e14 Contributor over 13 years ago in reply to GreenYamo
    Apparently the firmware, which is part of the binary blob loaded from the SD card,
    interrogates the RAM chip to find it's type, and initializes it differently depending
    on the type.  If an unrecognized RAM type is found, then booting fails.  No error
    message is displayed to the user, because booting hasn't gotten far enough.
    Perhaps LEDs could be used to indicate the failure reason, but that isn't done.
    On a typical PC, this firmware would be in a nonvolatile memory chip attached
    to the motherboard, rather than included with a downloaded OS image, so there
    would be much less chance that an older OS image would fail to work with a
    newer RAM chip.
    The firmware was apparently updated on github on January 16, and there was
    apparently a warning on the rpi download page earlier this month, but as of
    today, I don't see any warning on either the rpi or element14 download pages,
    and it looks to me that the element14 download images all predate the firmware update.
    Better communication would certainly be helpful when hardware changes are made
    that are incompatible with previous OS downloads.
  • GreenYamo
    GreenYamo over 13 years ago in reply to e14 Contributor
    As well all know, the Foundation are normally so good at clear communication and never resort to obfuscation image
    I really don't think it is acceptable that the answer for everything seems to be re-image, a lot of people have spent time getting builds just as they want them. It would appear you can just put on a new start.elf, but how many people will truly know how to do that ?
    I think there should be a prominent message on the downloads page and also a slip of paper in any new Pi's sent out, just to make things that little bit easier?
    Steve
    e14 Contributor over 13 years ago in reply to wallarug
    Cian,
    In hindsight it may be obvious, but it wasn't obvious to anyone at the time
    when users were reporting booting problems, even when they noted that they
    were using Hynix RAM.  For example, on this thread:
      http://www.raspberrypi.org/phpBB3/viewtopic.php?f=51&t=36194
    when Hynix RAM was specifically noted as a potential factor in booting problems,
    the only advise given was:
    "Raspberry's with Hynix or Samsung RAM is most likely not the issue.
    All Raspberry's should run the same images on all SD cards.  ...
    Have you tested your Raspberry with your friends power supply and SD Card?
    And with his peripheral devices? In his network? This excludes all other causes.
    If you've done that and it still doesn't work, you can be sure that you Raspberry broken."
    I think a lot of people have experience replacing or adding memory to a PC
    or laptop, with no worries about needing to update their OS or firmware.
    One of the selling points of the RPi is that a student can buy their own RPi
    to use at home with the same software used in the classroom.  But now we
    learn that the classroom SD card might not work on the home machine if the home
    machine has a newer RAM type.
  • johnbeetem
    johnbeetem over 13 years ago in reply to e14 Contributor
    Are the RasPi boards and software still at the "developer" stage?  (1 million developers and counting image!)  If so, there's a certain expectation that software is still evolving rapidly and glitches should be expected.  I don't think we've reached the "educational release" yet.
    It sounds like the Hynix issue is simply forgetting to announce an important technical issue.  Each firmware release should have "release notes" covering the most important changes, but it takes time to write release notes and they need to be posted at a prominent place in the RasPi Wiki.  If you know where they are, let us know.
    e14 Contributor over 13 years ago in reply to johnbeetem
    That's a very good question.  It seems the answer depends.  If you look at the
    RPi main blog, just about all you see is how it is being used, with essentially
    nothing about how the development is going, and so you could easily get the impression
    that the device has exited the "developer" stage.  But if you read the forums, just
    about all you see is complaints about various problems, including really fundamental
    problems like keyboards not working and problems booting, so from that you could
    easily get the impression that the device is still in development.
    I think it's interesting that the Hynix announcement yesterday on the main page was
    under the headline of "Public Service Announcement", as if to say we appologize for
    interrupting your regular stream of non-developmental news stories with a developmental
    news story.
    I have never seen a clear explanation of what the "educational release" would contain,
    except that it would be cased, and certified for residential FCC/CE compliance, and
    probably contain some 3rd party educational materials.  The RPi FAQ mentions the
    educational release only in response to a question about cases.
    I disagree with "forgot".   There is no forum for announcing important technical issues,
    or for keeping users informed about what problems are being worked.   It appears to me
    that the technical announcement on the main blog was only made after the unnamed
    distributor got fed up with all the returns.  Users would *love* to know what progress is
    being made on technical issues such as USB problems and X11 acceleration, but there
    is no such forum.
    > If you know where they [release notes] are, let us know.
    As far as I know, there are no release notes supplied with OS and/or firmware updates.
    I don't consider the foundation members to be lazy, nor to be oblivious to the usefulness
    of release notes, so this appears to me to be deliberate.
    Edited to add:
    Earlier this month there was an announcment on the RPi download page that the RISCOS
    download (I believe) was out-of-date.  That announcement has since been removed, which
    indicates to me that it wasn't a matter of "forgetting" to make an announcement.
