I have install motion on my raspberry pi
but do not no how to get in to the conf file to change it as show sudo nano/etc/motoin/motion/cong. I've tryed this but I get a messeage saying do not have pomision/ how can I change it so it will work
If you don't have permission to edit the file, then you'll need to execute the command as root.
To do this, prefix the command with 'sudo'.
It may ask you for a password. If you changed it, you'll know what it is. If you didn't change it, then the default password depends on the operating system you installed. Check here to find out:
http://www.raspberrypi.org/downloads
hope that helps.
sudo nano /etc/motion/motion.conf
