Raspberry Pi Forum pygame.camera hangs on get_image()
  • Replies 8 replies
  • Subscribers 707 subscribers
  • Views 1524 views
Ive got a problem with my pi freezing. it becomes unresponsive as soon as I call get_image() in my python script
Its a simple script...
[code]
import pygame
import pygame.camera
import pygame.image
import os
from pygame.camera import *
from pygame.locals import *
print "starting capture"
pygame.init()
pygame.camera.init()
size = (50,50)
cam = pygame.camera.Camera('/dev/video0', size, 'RGB')
print("cam created")
cam.start()
print("cam started")
img = cam.get_image()
print("gettting image")
[/code]
My script gets as far as "cam started"
I have succesfully taken a photo using the fswebcam program. No problem. It just wont take a photo via my python script.
I have uninstalled python along with pygame and resintalled and still have the same issue.
Any ideas?
Aidan
    Is this with the RPi CSI addon camera, or some other usb camera ?
    According to jamesh over on the rpi forums there's currently no v4l driver for the csi board, so /dev/video0 won't work for that camera.
    Apologies if I'm off track, but you don't say what camera you're using and as the camera addon has just been released....
    Yeah sorry,
    Its just a Philips usb web cam. The Pi seems to pick it up fine on start up and as with other cams Ive tried.
    Its so annoying! first little project ive set out to do and im falling at the first jump!
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    how are you going with this?
    e14 Contributor over 13 years ago in reply to wallarug
    Ive got no where with it, really frustrating.
    Im begining to think Its my pi. Dont suppose you fancy copying and pasting my above code and testing it on your pi?
    Aidan
  • GreenYamo
    GreenYamo over 13 years ago
    Hi Aidan, I had a very similar problem (read: Identical)  on a generic webcam, I fixed it by updating to the newest firmware available, they are making a lot of changes in that space at the moment, so it is well worth trying.
    https://github.com/Hexxeh/rpi-update
    Hope that helps - note that updating the firmware is not the same as downloading a new image. The images are updated every now and then, the firmware can go through a lot more revisions.
    Steve
    e14 Contributor over 13 years ago in reply to GreenYamo
    Thanks for this great info Steve.
    Ive got a project on at the moment but will definitaely try updating the firmware in the next couple of weeks.
    Tar for that
    Aidan
    Steve you legend!
    That fixed it. So happy about this! Months Ive been trying to figure this out.
    Thanks for the pointer.
  • GreenYamo
    GreenYamo over 13 years ago in reply to e14 Contributor
    Hi Aidan, Glad it worked ! Like I said I did have the identical problem, but that doesn't always mean it is an identical solution :-)
    Have fun with the Webcam!
    Steve
