Raspberry Pi Forum RPi camera
  • Subscribers 708 subscribers
  • Views 1087 views
RPi camera
tabarus12
tabarus12 over 13 years ago
Hey yal, say does any of you know if Rasperry pi can proccess the video from a wefcam?
  • penguintutor
    penguintutor over 13 years ago
    Short answer is "yes".
    Long answer is "it depends"
    It depends upon the type of webcam, although Linux does have good support for most webcams a few may not work "out of the box". It also depends upon what you want to do with the video and what else is running at the same time.
    The Raspberry Pi camera has the advantage that it doesn't have to go via USB which adds an additional overhead.
  • GreenYamo
    GreenYamo over 13 years ago
    Omar, i'd like to second Stewart's post. I've been playing around with webcams for a week or two now, and that pretty much sums up my findings so far. Three webcams, not all worked the same or at all in some cases. One thing I would say though is that they have been doing a lot of work on the firmware for the pi, and a recent update made a lot of things better. One of my better working ones is a generic model that cost less than £5 so it is worth trying as it only costs a quarter of the official Pi camera.
    I also have one of the 'real' Pi cameras though and I have to say i'm quite impressed. The pi is currently mencoding a time lapse video of the view out of my back window !
    Steve
  • tabarus12
    tabarus12 over 13 years ago in reply to GreenYamo
    Thanks for the info Ill take a look at your info and toy arround to find the best solution for me, again thanks a lot for the info its very clear and usefull it solves my questions, Ill let every one know the best solution for future reference since I have the latest Pi model up to date.
    If it is a webcam yes i am pretty sure it will connect to a raspberry pi
    Nolan,
       As Stewart and Steve have mentioned, webcams on the RPi have been troublesome,
    especially at higher resolutions.  Just because a webcam uses USB and works on a PC
    doesn't necessarily mean it will work on a RPi.  A lot of work has been done recently on
    USB issues, and the fixes can be tried by downloading updates to  your OS kernel.
    There is a post linking to relevant detailed explanations of the USB issues at:
    http://www.element14.com/community/message/77957#77957/l/rpi-usb-issues-explained
    Apart from the obvious RPi camera module which works out of the box with the latest Raspian image I am using a USB Logitech C110 which cost a tenner and also works out of the box. The biggest problem with some webcams is power as there is limited power available on the USB ports so if you're running a camera and a wifi module you might struggle unless you use a powered USB port. The RPi camera module doesn't have this issue and the C110 that I am using seems to be low powered and works with a WiPi.
    You can find a list of tested webcams here: http://elinux.org/RPi_VerifiedPeripherals
    You can see my webcam in action with live streaming duck cam here: http://bambuser.com/channel/duckcamuk
