Raspberry Pi Forum software engineering;  was: Is this official blog article intended as a joke?
  • Replies 62 replies
  • Subscribers 708 subscribers
  • Views 9772 views
http://www.element14.com/community/groups/raspberry-pi/blog/2013/05/24/getting-started-with-raspberry-pi--part-1
"With a  Raspberry Pi in hand, robotics is no more a fancy imaginary world of big and serious people but a real and authentic one."
"big and serious people"  Really???
"fancy imaginary world"  Really???
"With a normal computer that has a monitor, keyboard, mouse, printer and modem connected, hardly anything can be done, except the intended use."
"printer port"  Really???   have you heard of USB?  We're up to USB 3.0 now.
"modem port"  Really??? have you heard of ethernet?  We're up to 1 and 10 Gbit now.
Have you heard of the PCI Express bus on PC's?  (or formerly ISA and PCI)
"non-availability of an easy programming environment"  Really?!?!?
  • johnbeetem
    johnbeetem over 13 years ago in reply to morgaine
    Morgaine Dinova wrote:
    coder27 wrote:
    The solution to complexity is abstraction.  A single person can run a large company
    or run a large nation, but not by doing all the jobs that a sole proprietor does.  Instead,
    they operate at much higher levels of abstraction.
    Abstraction is part of the solution, but it's not sufficient by itself.  With abstraction alone, computers will continue to do exactly what we tell them to do, and will inevitably end up doing the wrong thing because it is entirely beyond our mental ability to fully understand (let alone specify) the behavior of a non-trivial system.  Removing unnecessary detail and bringing the language of specification closer to the natural language of the application domain through DSL abstraction clearly helps, but it is not enough.  The desired complex behavior still has to be defined, somewhere, and that's the problem.
    Another problem is that of leaky abstraction layers.  My favorite example of this is C.  As I said earlier in this discussion, I think of C as a portable assembly language which uses high-level notations, and if you think of C that way it works very sharply indeed.  However, if you think of C as a high-level language, you will be disappointed at run time when machine-level behavior damages your nice high-level model.
    Just adding abstraction layers can be problematic, if only because the abstraction layer may hide terrible performance problems that you'll only uncover when the system is fully deployed.
    Also, IMO opinion many large (and even small) companies and countries are very poorly run whether or not their leaders are capable of abstract thinking or common sense.  I'm sure you can think of examples.  I believe the principal cause of this is the Law of Large Organizations:
    In any Large Organization, Loyalty will always be rewarded over Competence.
    Come to think of it, many large software systems suffer from this as well image
  • johnbeetem
    John Beetem wrote:
    Actually, IMO humans are quite good at working with complex things once they have come up with good notations -- textual and graphical -- to describe them.  However, the development of those notations usually takes decades or centuries.
    It's interesting (or perhaps sad) to contrast that with the typically short  timescales of product and company planning in the commercial software world.  One might be tempted to suggest that open source could be the answer, since it doesn't end-of-life code with quite the same degree of profit-oriented ruthlessness, but alas even open source programs bit rot and stop working owing to dependencies and changing architectures.
    The long-term view just isn't there, and may not even be possible.  Things change, it's part of progress.  Whatever solutions we come up with for the software crisis, they'll need to be able to cope with the current state of technology.  I very much doubt that refinement over ages will help much.
    Open source certainly helps, since it's not subjected to the limitations imposed by having to make money image
    Ars longa, vita brevis.
  • morgaine
    morgaine over 13 years ago in reply to johnbeetem
    Unfortunately open source + free software is not fully isolated from the ill effects of preoccupation with money, short-term "product" focus, business planning and corporate competition.  Although individual projects may be created and developed by one or a small number of non-commercial and wholly altruistic enthusiasts, as soon as a project blooms into a global community resource it gains contributors with different needs and aspirations, many of them in direct support of business requirements and a focus on product and competitive advantage.
    Open source code inevitably gets modified to support the latest devices or architectures, which typically undoes any previous validation that may have been done on it.  New drivers or patches are often added by corporate developers for whom getting support for a new gizmo is part of their jobs, but who will generally not continue to support their changes once those gizmos have been EOL'd in the company product cycle since they will not be paid to do so.  And unless they are exceptionally community-minded, they'll not be going out of their way to create generic infrastructure that supports their competitors, but instead focus on providing best support for their own requirements as their main priority.
    So, open source doesn't exist entirely within an isolated collaborative space as is sometimes portrayed.  Even with everyone doing their level best and not having hidden agendas nor being deliberately evil, the nasty realities of the world outside FOSS idealism do intrude and mess things up to some degree.  Old code that is perceived as crufty is often removed purely to keep the more modern code sane, which means that honing code to a high state of reliability and trustworthiness over long periods of time just doesn't happen --- it bit rots or gets modified long before then, so validation and long-term stability just isn't useful or even possible in practice.
    This is why I say that any solution to the software crisis cannot come from the "decades or centuries" that you mentioned, not even in FOSS.  It will have to be applicable to the code that exists at any given point in time or it won't be addressing the problem.
    Morgaine.
  • johnbeetem
    Unfortunately open source + free software is not fully isolated from the ill effects of preoccupation with money, short-term "product" focus, business planning and corporate competition.  Although individual projects may be created and developed by one or a small number of non-commercial and wholly altruistic enthusiasts, as soon as a project blooms into a global community resource it gains contributors with different needs and aspirations, many of them in direct support of business requirements and a focus on product and competitive advantage...
    Good points.  However, I would say that FLOSS (Free-as-in-Liberty Open-Source Software) generally benefits from participation by for-profit entities as long as the software uses a copy-left license.  Yes, money-driven entities will want to add code for their own purposes, but if they want to use immature FLOSS for serious purposes they'll find bugs and they'll be required by the license to publish the fixes to those bugs.  The rest of the FLOSS community can scoop up the bug fixes and improve the quality of the software.  It's very hard for an individual developer or even a small team to catch and fix everything, so having people paid to help is usually beneficial.
    Example number 1 is obviously Linux.  It has grown amazingly over its lifetime, both in use and... in size.  I think of Linux as a terrific mainframe OS kernel, and when you think of it that way then its size isn't so shocking.  I think there's room for a light-weight personal computer OS, but I think we'll have to wait for Microsoft to complete its self-destruction first.  I don't think the wait is going to be long -- they seem pretty eager. image
    Linux benefits from having a foul-mouthed benevolent dictator image to enforce quality, and from early adoption by IBM who defended Linux from early attempts to destroy it.
    Example number 2 is Open Office.  That's a good example of a project that had to "fork it" to remain FLOSS.  I agree with RMS that you can't get the benefits of open-source software without the Four Freedoms, because otherwise corporations will take a snapshot of OSS and then keep all improvements to themselves.  It will be interesting to see how long Open Office stays around versus Libre Office.
    e14 Contributor over 13 years ago in reply to morgaine
    Remember Bertrand Meyer's very insightful work on Eiffel, in which preconditions, postconditions, and invariants played such an important part?   He embedded semantic constraints into software components, although his focus was on simple design contracts at a level far below anything related to what people might call "commonsense".  Unfortunately, static constraints are fundamentally at odds with flexibility and reuse, so we see them only very rarely in practical software beyond basic assertions for defensive programming.  We are as far away as ever from the model of companies or nations working in software.
    Yes, I'm somewhat familiar with Eiffel's semantic constraints, but I've never heard that "static constraints
    are fundamentally at odds with flexibility and reuse", so I'd be interested in further elaboration or references.
    I am aware of various issues such as whether constraints should be statically checked at compile time vs.
    run-time checked.  It seems both are needed.  I'm also aware of some confusion when inheriting constraints,
    whether you should inherit the union of the constraints of all your ancestors, and how to override any constraints
    you don't want to inherit.  But I assume that constraints are relatively rarely used in practice due to their availability
    in mostly non-mainstream languages.
    In any case, I think abstraction as a solution for complexity doesn't necessarily depend on the power of
    available constraint mechanisms.  It mostly depends on the suitability of divide and conquer, which allows
    for a hierarchical decomposition of the problem.  A CEO can run a company because the company can be
    divided into various departments, each with a vice president, and with limited interaction between departments.
  • johnbeetem
    johnbeetem over 13 years ago in reply to e14 Contributor
    In 1984, there was a USA TV comedy series called Empire about boardroom shenanigans at an unnamed USA corporation.  The hero is a young man from R&D who was made VP because of competence, and you get to watch him try to swim among the sharks.  It only ran 6 episodes -- I think it struck a nerve with the sponsors.  Not yet on DVD, alas.
  • morgaine
    morgaine over 13 years ago in reply to e14 Contributor
    coder27 wrote:
    Yes, I'm somewhat familiar with Eiffel's semantic constraints, but I've never heard that "static constraints are fundamentally at odds with flexibility and reuse", so I'd be interested in further elaboration or references.
    Oh it's nothing particularly deep, just an inherent consequence of adding constraints to any code.
    In functions for example, without additional constraints, the domain of a particular function is given by the types of its declared parameters (or the types of its supplied arguments if function parameters in the language are untyped), and so those input types determine the extent of the function's input space.  The range of the function (ie. its set of possible outputs or the extent of its output space) then follows naturally from the set of possible inputs constrained only by the definition of those input types.
    If you add additional constraints within the function to narrow down the allowable function domain to less than the full input space given by its input types then the output range will frequently be more limited as well, ie. the extent of the output space will be smaller.  Typically this is done to bring the semantics of the function more into line with the desired behavior of the application, for example to narrow its domain and range for the purpose of defensive programming.  The function will then have a more limited set of possible uses than would its original version that is constrained only by its input types, which is why adding semantic constraints is fundamentally at odds with flexibility and reuse.
    The function will then have a more limited set of possible uses than would its original version that is constrained only by its input types ...
    OK, I understand.  I think normally this is no great loss, because the region of the domain
    that is trimmed is usually erroneous or uninteresting.  For example, adding a constraint to ensure
    that a parameter is nonzero, because you intend to use it as a divisor.  This allows pushing the
    divide-by-zero check to the caller rather than the callee, which is a good thing, because the
    compiler may be able to remove it based on information known at the call site.
    e14 Contributor over 13 years ago in reply to johnbeetem
    John Beetem wrote:
    I have met way too many soi-disant software engineers who hate writing software (not to mention documentation), so they mash together inappropriate modules from Edsger Dijkstra knows where.  I have also met way too many engineering managers who want something quick-and-dirty now instead of doing it right -- and then re-doing it righter after learning from the first go-around.
    My experience is that a large proportion of software engineers actually like writing software, or at least did at some point.  But anyone who's done a couple of projects will have seen the pattern of the clueless engineering managers who just won't listen and will have quickly become jaded to the whole process.  They know they're probably going to have to do at least a couple of ground-up re-writes due to whatever daft managerial decisions get imposed.
    If they learn anything the first time round it should be to never listen to the manager!
  • Dudley
    Dudley over 13 years ago in reply to e14 Contributor
    This is an interesting discussion that I've been lurking on with some interest. I think everyone makes valid points, and I think that any language is the wrong language to use when it is used wrong. Java (my language of choice), which many touted as being the answer to many people's problems, still has a lot of problems inherited from C and C++, Ultimately, it's quite possible to write bad code in any language. The more powerful the language, the easier it is to paint yourself into a corner, and find yourself with a sticky problem that you have to fudge your way out of.
    Speaking from my own experience, deadlines are necessary, you need something to focus the mind and finish up. But as the deadline looms, you have to make short term compromises that tell yourself you will come back to at a later date, and then don't because after the deadline has passed you have new work to work on. Those compromises, or the the code that is built on those compromises, cause problems further down the line. Good commenting or peer review can deal with this, but too often, neither happen.
    The real problems arise when the people setting the deadlines are focussing too much on the short term. Sure, it makes good business sense to minimise your spend, but all too often PMs decide on the quickest or cheapest solution offered to them, without caring about the effects this causes. "Act in haste, repent at leisure". Quick and dirty solutions often cost a lot more in the long term than the slower, better solution, but some engineers have a terrible time trying to persuade a PM of why they should get 8 weeks to do a solution when a Q&D one can be done in 2. A PM in a previous job once said to me "Do the quick and dirty solution, but do it without writing the bugs". These days I show people the iron triangle.
    Now, that all said, it's fair to say that all software ships with bugs; it is part of the nature of software, and it happens for all the reasons everyone said. Bad coders, wrong choice of language, poor management decisions, quick & dirty solutions, sloppy testing, the list goes on and on. The trick is to accept that there will be defects, and making sure that none of them break functionality or cause a terrible user experience. A good iterative QA cycle is essential for good software.
    However, what got me out of lurking on this post and actually posting on this discussion was the last post by Selsinork, which reminded me of an excellent article once written by Orson Scott Card. This is a jaded example, but it definitely points at some of the key problems in software development - how it is handled by non-software types, and especially by management. The world has changed in many ways since this article was written, but in many ways, it remains the same. A large number of problems are caused by external people not understanding either how software works, or how the people who work on software work.
    I think it's as important to teach young coders how to deal with bad managers as it is to teach coders how to code.
