Raspberry Pi Forum PiFM - Raspberry Pi as a trasmitter - Music problem
  • Subscribers 703 subscribers
  • Views 2416 views
wallarug
wallarug over 13 years ago
I downloaded the required files from here: http://www.icrobotics.co.uk/wiki/index.php/Turning_the_Raspberry_Pi_Into_an_FM_Transmitter  on the DOWNLOAD link.
I have everything working with the standard settings and a new frequency, BUT I can not seem to get my music files to play correctly.  They are too slow.
I converted them using Switch file converter to 44100 Hz @ 16 bit Mono  which it says is the right format on the wikipedia page I linked above but they don't seem to play right.  All the voices are too deep and the music plays slower than expected.  I tested on my PC but the result is different to when I play on the radio.
Does anyone have any ideas on how I should fix this?
    shabaz over 13 years ago
    Hi Cian, these ae just guesses but, it could be the conversion that may be faulty, a quick test would be to see the file size, vs. the expected length of the audio, or, it may be expecting an overclocked Pi. Hard to know! By timing it, you may be able to figure out if it is (say) 1.5 times slower or 2 times slower, etc., and that may provide the clue.
  • wallarug
    wallarug over 13 years ago in reply to shabaz
    I think I just solved it!
    they assumes that the music being 16 bit automatically means that it is at 44.1 KHz.
    Just test with 16bit compression with 22 050 Hz timeing and it seems to work nicely!
    Shall confirm with mp3 conversions.  That was a rip from CD to .wav 1411 kbps --> 16 bit mono 22 050 Hz
    More info coming soon about mp3 's
  • wallarug
    wallarug over 13 years ago in reply to wallarug
    CONFIRMED!
    ALL MUSIC NEEDS TO BE 16 bit resolution with 22 050 Hz timing!!
    Going to try another song now!!!!!!
    This is really cool.  (keeping the law in mind is good as well image)
    I shall report back with test 3 results!
    shabaz over 13 years ago in reply to wallarug
    Cian Byrne wrote:
    CONFIRMED!
    Great! Glad it works :-)
  • wallarug
    Is there any chance that this could be changed on the wiki site?  so that others are not mislead?
  • packetgeek
    packetgeek over 13 years ago
    How much load does this put on the Pi?  I'm thinking that you might be able to run Liquidsoap on the Pi and hook the output of that to new code.
