Raspberry Pi Forum RASPBERRY PI STARTER KIT, RASPIAN, CASED-UK
  • Subscribers 702 subscribers
  • Views 596 views
Do any of you guys out there know what is in clouded in the RASPBERRY PI STARTER KIT, RASPIAN, CASED-UK bundle?
Does it include a keyboard and mouse?
Littleswany (Noah)
    Iv'e just contacted the live support service and they've confirmed that the kit contains "the Raspberry Pi which is cased. Power supply and the SD Card with operating system". Hope this helps.
  • kellyhensen
    kellyhensen over 12 years ago
    The element14 Raspberry Pi Starter Kit has the following four items in the box:
    (1) Raspberry Pi Model B (512MB) with and ARM11 processor
    (1) 4GB SD Card pre-installed with NOOBS pre-loaded
    (1) Black, ABS Plastic Case for use as Raspberry Pi enclosure - usually two pieces that snap together with openings for all of the "standard" inputs.  (that is, if you want to connect to the GPIO, this case will have to be removed)
    (1) Micro-USB Power cord/adapter
