Raspberry Pi Forum connections on raspberry pi
  • Subscribers 705 subscribers
  • Views 951 views
tabarus12
tabarus12 over 13 years ago
Does anyone know where I can get a detailed connections diagram for the Rpi, one that includes the Jtag connections.
  • guzunty
    guzunty over 13 years ago
    Hi Omar,
    The schematic is here: http://www.raspberrypi.org/wp-content/uploads/2012/04/Raspberry-Pi-Schematics-R1.0.pdf
    A later rev is here: http://www.raspberrypi.org/wp-content/uploads/2012/10/Raspberry-Pi-R2.0-Schematics-Issue2.2_027.pdf
    There may be more iterations in the upload cache if you're looking for a specific revision.
    JTAG pins are on P2, on sheet 4.
    HTH, or are you looking for guidance on connecting a JTAG hardware debugging probe? If so, there is some discussion of that here:
    http://raspberrypi.stackexchange.com/questions/1437/has-anybody-tried-to-debug-using-jtag-bdm
    Derek
    http://elinux.org/RPi_Low-level_peripherals
  • guzunty
    Yes, I see now that P2 is the VideoCore JTAG only and not for debugging.
    There is this comment on coder27s link:
    It is also possible to reconfigure GPIO connector pins P1-7, 15, 16, 18, 22 (chipset GPIOs 4 and 22 to 25) to provide an ARM JTAG interface.[11] However ARM_TMS isn't available on the GPIO connector (chipset pin 12 or 27 is needed).
    Unfortunately, the given link [11] appears to be broken or at least doesn't take you directly to the information.
    e14 Contributor over 13 years ago in reply to guzunty
    see p. 13 of
       http://magikh0e.ihtb.org/pubPapers/Raspberry.Pi.Hacking.pdf
    There are some additional notes here:
      http://www.raspberrypi.org/phpBB3/viewtopic.php?f=9&t=1431
      http://www.raspberrypi.org/phpBB3/viewtopic.php?f=7&t=5894
      http://www.raspberrypi.org/phpBB3/viewtopic.php?f=72&t=19623
