Raspberry Pi Forum Viewing MJPEG raspberry pi motion stream
  • Replies 18 replies
  • Subscribers 705 subscribers
  • Views 4892 views
I have created a IP webcam using raspberry pi. I used Sakis3g n Motion webcam software to do this. The stream obtained is in MJPEG format.
So, whenever I open that link, I can only see the 1st image on my browser (on my windows 7 PC). it does'nt automotaically update the stream every few seconds.
How do I view the stream on any browser ??? Are there any plugins ???
Does any browser support on PC (windows 7)this MJPEG stream?? If so, which one and which version of the browser ???
    There is a difference between the stream that is created as a file on the Pi when motion is detected and the actual stream via a browser.  The browser is showing you streamed jpegs.  I have this working in Firefox but in IE it only justs tries to download the jpeg files.
    You may also take a look at this.  http://sirlagz.net/2013/01/07/how-to-stream-a-webcam-from-the-raspberry-pi-part-3/
    For me in my firefox browser, it just shows the 1st image, it doesnt refresh stream every few seconds.
    Which version of firefox did you use to get the live stream working properly ???
    Firefox version is 21.0.
    Are you on the latest version if wheezy with all updates?
    Post your motion.conf file and I will compare it to mine.
    yes i"m on the latest version, just updates it 5 weeks back
    The values of the parameters in motion.conf
    daemon off -> daemon on
    process_id_file -> /home/raspbian/motion/motion.pid
    width 320 -> 640  //Width of the camera feed
    height 240 -> 480  //Height of the camera feed
    framerate 15
    max_mpeg_time 12000 //Larger the value, smaller the video file
    ffmpeg_cap_new off  //Set to OFF as video is not recorded
    webcam_quality 75
    webcam_motion off -> on //Changed  to 'on' so only 1 frame per second is broadcast to the web cam server until actual motion is detected)
    webcam_localhost on -> off (change this to 'off' so you can view the webcam stream remotely)
    webcam_maxrate 1 (the maximum number of frames per second the web cam server will show in your browser, try 10 for starters)
    webcam_localhost on -> off  //Changed to 'off' so that webcam stream can be viewed remotely
    webcam_maxrate 10   // The maximum number of frames per second the web cam server will show in your browser
    Which webcam_maxrate setting are you using?
    the one under live webcam server.
    In the config you pasted above you have 2 of the same setting.  One set at 1 and one set at 10.
    yes , I have used both of same setting.
    Is this causing problems ??
    What is your settings for these ???
    So, is your browser refershing the stream automatically every few seconds ???
    You can download my motion.conf file here https://www.dropbox.com/s/n6p97e419tnbn46/motion.conf.
    It refreshes the stream automatically in firefox.
    I also downloaded an app for ipad/iphone called CameraView ($.99) This works great to view the stream video.
    I did some more research and found that IE basically has no compatibility for MJPEG.  Other browsers do suport it but have issues with it.  Maybe you should look into turning the Pi into a web server and then using the webserver and either HTML or Java script to render the video as discussed in the links below.
    http://stackoverflow.com/questions/5269376/cross-browser-solution-for-displaying-mjpeg-stream
    http://forums.asp.net/t/1853365.aspx/1
    Final thought.  Make sure you are using motion version 3.2.9 as previous versions had issues with streaming in FireFox (http://www.lavrsen.dk/foswiki/bin/view/Motion/FrequentlyAskedQuestions#Firefox_shows_a_still_image_44_that_never_stops_loading_44_if_I_press_F5_it_starts_refreshing.)
    Thank you very much!!
