Raspberry Pi Forum Run Cronjob from Web server
  • Replies 7 replies
  • Subscribers 707 subscribers
  • Views 1547 views
I have a Pi that has motion installed and working.  I am consuming this and displaying it on a page that is also running on my LAMP stack on the Pi.  I don't want the camera to run all of the time and would like the ability to start and stop the motion service (via cronjob) by clicking a link on the page.  So the all in all is I need to execute a cronjob by clicking a link on the site.  Ideas?
This will all be secured behind a firewall and if made public with a username and password so you can skip the risk speech on this one.
    There are some examples here using javascript:
    http://stackoverflow.com/questions/5636051/cronjobs-in-node-js
    depending on whether you're worried about restarts.
    Restarts are not a problem as I have some cron jobs in place to handle that.
    I am not a Java programmer so you may have to bare with me.  I am not looking to schedule jobs with js but rather to fire one with it with a click of a link.
    example:
    Link would be "Start Motion"
    on click would do - sudo service motion start
    So a cron job may not even be necessary but they already exist.  Launching a command with a link click would work as well.
    Javascript is different from Java.  Just unfortunately similar names.
    Edited to clarify:  Javascript can be run either client-side or
    server-side.  I think you want server-side.
    see http://en.wikipedia.org/wiki/Server-side_scripting
    Instead of Javascript, you might be better off with PHP for
    server-side scripts.  In PHP, you can execute a shell command
    using shell_exec() or exec().
    http://stackoverflow.com/questions/7540847/html-button-to-call-php-shell-exec-command
    I have changed directions and am now going down the path of using cgi scripts.  I have the scripts running from the web but the "service start" comand never fires.
  • Problemchild
    Problemchild over 13 years ago in reply to e14 Contributor
    A Cron job is something quite independant to the webserver call.#
    The Motion S/W can be started and stopped via Startup/Shutdown scripts put into the Crontab via a comman like crontab -e orwhat ever tool you have used to edit the file.
    You could have this ssytem run independantly to the "on demand"  web call but in both cases you would need to have a check inthe startup script to check it wasn't already  running and also have the shutdown script not complain too much if the Motion S/W has been stopped already by the web script for example.
    Another way would to have the Web server call touch a file when you want to start or stop the Motion S/W then have a Crontab script check it every  min and stop or start motion appropriately ...Remember that cron has a granularity of 1 min here !!
    Hi coder27,
    I got a simple question,, I am only leary of power surges,,, but may I plug my R-pi into a power strip and just turn everything on and off with it ?
    Sonny
  • mgt6910
    mgt6910 over 13 years ago in reply to e14 Contributor
    The shutdown that you propose is exactly what I do after entering the command   "sudo shutdown now".    Wait 30 seconds for a few lines of shutdown messages, then throw that switch.   Ditto for startup, I have everything on a strip: screen, Pi, USB-Hub. No problems.
