Raspberry Pi Forum Ethernet Causes Mouse Problems
  • Replies 12 replies
  • Subscribers 705 subscribers
  • Views 1972 views
  • x
  • bottom
  • ethernet
  • b
  • stick
  • wireless
  • mouse
jreeve17
jreeve17 over 13 years ago
Hello, I have just purchased the Raspberry Pi Model B and have found a problem. Whenever I plug the Ethernet Cord in. The mouse (in x) drops to the bottom of the screen. Also, and keys i press become stuck and keep repeating untill I press another. Without the Ethernet cable, however the Pi works fine. I have tired reinstalling the  wheezy and different mice, but nothing works. The Keyboard also works fine, as I have been using it with my laptop with no problem.
I am using the Rasbian Wheezy with the GE Multimedia wireless keyboard and mouse.
How would I be able to fix or prevent this problem from happening?
Thanks in advance for any help you can give me.
Update: This problem is now happening even without the Ethernet cable plugged in. I have no idea why this is happening and still need help.
    e14 Contributor over 13 years ago in reply to jreeve17
    Would getting a new Pi help solve this problem?
    Probably not.  The problem is most likely that the RPi's USB system does not
    work well with certain wireless keyboards.  If you google for site:raspberrypi.org
    mouse bottom of screen, you will find a number of threads without solutions.
    If you are considering exchanging it, you might want to consider
    exchanging it for a Beaglebone Black, which as far as I know works
    fine with wireless keyboards.  It doesn't do 1080p video decode,
    but other than that, it is generally considered to be a better value
    than the RPi.
    e14 Contributor over 13 years ago in reply to johnbeetem
    i think everything is fine !!!!!
