Raspberry Pi Forum Beta testers wanted for pimon.org
  • Replies 10 replies
  • Subscribers 708 subscribers
  • Views 1018 views
  • troubleshooting
  • monitoring
  • cloud
  • hosted
  • raspberrypi
  • reporting
  • service
  • remote
Hi all,
im looking for beta-testers for monitoring and reporting application available via http://pimon.org
Any tech-savvy users willing to spend a few minutes testing the app or just sending me any type of feedback are much needed!
Thanks in advance!
Marcel
  • morgaine
    morgaine over 13 years ago
    Such a Pi-oriented service should of course run on a cluster of Pi boards. image
  • wallarug
    wallarug over 13 years ago in reply to morgaine
    There has got to be a better and nicer way of displaying and using that information.
    Is it automatically updated, or manually?  from my impression it is manually updated.
    Also:  program did not run correctly.
    Can't locate common/sense.pm in @INC (@INC contains: /root/pimon/bin/../lib /etc/perl /usr/local/lib/perl/5.14.2 /usr/local/share/perl/5.14.2 /usr/lib/perl5 /usr/share/perl5 /usr/lib/perl/5.14 /usr/share/perl/5.14 /usr/local/lib/site_perl .) at /root/pimon/bin/send line 6.
    BEGIN failed--compilation aborted at /root/pimon/bin/send line 6.
    Any ideas?
    e14 Contributor over 13 years ago in reply to wallarug
    Hi Cian,
    any suggestions regarding the presentation of the information is much appreciated! I also think that there should be more interactivity and maybe more pictures to demonstrate the information in more visual way.
    Regarding the Perl problem - I have removed the dependency on common::sense module in the code - much appreciated if you could test again.
    The data are manually updated, but you can set-up the cron job to do that every 10 minutes or so. Ill put some more information on the page about that.
    Thanks for the feedback - that is exactly what I need!
    Marcel
  • wallarug
    wallarug over 13 years ago in reply to e14 Contributor
    I won't have time to test it tonight but regarding the presentation of the information, I believe that you could make it look a whole lot better by including graphs and maybe (if it is possible) live information streaming every 2 seconds or so.  That way, you could use that data in a dynamically updating graph for the core_freq and temp parts.
    In other notes...  I noticed you are using Jquery mobile.  This is a very powerful framework to be using.  I have been experimenting with it over the past 6 months and found some very good sources for the presentation of information:
    Search filter:  http://jquerymobile.com/demos/1.2.0/docs/lists/lists-search.html  -  This could be useful when searching many for different Nodes.
      Pop-ups:  http://jquerymobile.com/demos/1.2.0/docs/pages/popup/   - This could be good for displaying graphs and images.
      Dialog Boxes:  http://jquerymobile.com/demos/1.2.0/docs/pages/dialog/index.html  - Think of using this for error messages.  (have not tested).
      Graphs:  http://therockncoder.blogspot.com.au/2012/05/jquery-mobile-charts.html  - I have not done graphs before but this looks like a good start.
    I hope my feed-back is useful and I also hope I can be an on-going contributer to this project.
    EDIT:
    One mroe thing.  Could you change the tittles in col. 1 to words that have a meaning to the user... for example:
    cpu_serial:
    could become:
    CPU Serial No. :
    That way it is a better user experience.
  • wallarug
    ok.  Added PiCam to your database.
    http://pimon.org/pi.php?u=gskx3iizos
    Signing off for tonight!
    Great feedback! Thanks. I will be including more graphs and interactive parts in the near future. Thanks for the links - very helpful.
    I will be changing the cpu_serial ant other key names tonight!
    Still looking for more beta-testes.
    http://pimon.org - the installation / testing takes about 20 seconds
  • wallarug
    Hey,
    The software only works if you have eth0 connected.  Could you please add support for wlan0 please.  I need to monitor my Pi Remotely (without cables).
  • edwin@oetelaar.com
    edwin@oetelaar.com over 13 years ago
    Hello Marcel,
    Nice of you to make this project.
    I do have a question : how long are you going to keep your site up and running?
    I just got a reminder from Amazon that my EC2 free tier was going to end so, I guess you have something similar?
    Running servers taken time/effort/money so when the thrill of the project wears of, do you shut the server down and we lose our functionality?
    Greetings,
    Edwin van den Oetelaar
  • wallarug
    wallarug over 13 years ago in reply to edwin@oetelaar.com
    Apparently the project is 'community funded' and will 'always remain free' and running.
    On another note:  I fixed the source code so that I can use the software on wireless.  This is done by replaying the one occurance of 'eth0' to 'wlan0' and then it works!
  • wallarug
    Might I make one other suggestion.  The Model A is not supported by the app either.
    - add support / option for wireless
      - add support / recognition for Model A's and Rev 2
