Raspberry Pi Forum PiFace Noob
  • Subscribers 703 subscribers
  • Views 606 views
PiFace Noob
ge0rgej
ge0rgej over 13 years ago
Hi
I have just setup my PiFace and am able to access the PiFace emulator
At the moment I am just looking at what switches what ..... and the PiFace possibilities
Am I right in assuming that with no scripts in place I should be able to put a switch
across Pin 0 and 0v ... and once activated the emulator will show the output relays
changing over ?
    mcb1 over 13 years ago
    George
    I think you might want to download the documentation that is available for it.
    http://www.element14.com/community/docs/DOC-53057/l/piface-get-started-guide
    The inputs will show in the emulator, but you need to click the box.
    The relays can be controlled in the emulator.
    There was one conversation regarding the jumper settings.
    You might need to search using the term PiFace ...if I recall it was a comment and possibly on a RoadTest.
    However if you set them as per the picture here (click to enlarge it) it will work
    http://www.element14.com/community/roadTestReviews/1452
  • ge0rgej
    ge0rgej over 13 years ago in reply to mcb1
    Thanks again
    I did read throught the start up documentation that you linked to.
    I thought at first that the jumper settings might be the problem but they are all set as the picture
    you also linked to
    In the emulator .....
    When I hover over S1-S4 they all light up as they should
    When I click Overide Enable and then click on Output Pin 0 and Ouptput Pin 1 .... i can see the relays changing over
    Here's the problem - when I connect a switch across Pin 0 and 0v on the Input relays I would expect to see the output relays changing over in the emulator - but they dont ?
    mcb1 over 13 years ago in reply to ge0rgej
    George
    The PiFace is a set of 8 inputs and 8 outputs.
    They are seperate and you program the RPi to do the interfacing.
    ie you might set it to operate the relay for 10 secs, or delay when it operates.
    There are plenty of examples around using python to do the bit in-between, both on the site and off.
    Cheers
  • ge0rgej
    Thanks Mark
    I found the answer to my question. Enabling 'Keep Inputs Updated' in the Piface emulator allowed me to see whether the switch was working
    George
    Not obvious and I'm not sure why it wasn't defaulted to ON.
    mark
