Raspberry Pi Forum PiFace Output Relays
  • Subscribers 706 subscribers
  • Views 623 views
ge0rgej
ge0rgej over 13 years ago
Hi
Can anyone tell me if the PiFace relay contacts should only be treated as volt free contacts - or can
a load be switched across them ..... if so can anyone tell me the maximum load
thanks
George
    mcb1 over 13 years ago
    George
    A volt free contact means there is no voltage on them from the host or control circuitry.
    Have a look here for the answer to your other query
    http://www.element14.com/community/roadTestReviews/1468
    mark
  • ge0rgej
    ge0rgej over 13 years ago in reply to mcb1
    thanks for your reply - I appreciate the volt free concept
    My question is if I switch an external voltage across the  Common / Normally Closed output relay what is the maximum
    load (A) the contacts will take
    George
    mcb1 over 13 years ago in reply to ge0rgej
    I presume you read this bit.
    The relays must not be used to switch voltages greater than 20V or currents greater than 5A
    mark
  • ge0rgej
    I did - thanks image
    George
    Cheers
    I've made a comment (and chased an inapproriate blog showing mains being used) that this really needs to be in the documentation and starting guide.
    Having it on the outside of the box, is really not the best practice.
    For anyone reading this
    While a component may be rated for a maximum, it is the environment around that often dictates a lower limit be applied.
    For the PiFace, the pcb is NOT designed for mains voltages, and the track widths don't suit any higher currents.
