Raspberry Pi Forum What Model of Pi do I have?
  • Replies 22 replies
  • Subscribers 711 subscribers
  • Views 2905 views
  • help
  • what
  • network
  • kicks
  • windows
  • for
  • model
josh_j
josh_j over 12 years ago
A friend a while ago gave me a Raspberry Pi. I really like it because it's fun to use just for kicks outside of using a Windows machine. But I have two questions. First, and the main one, how do I tell which model of Pi do I have. Two how to I connect the Pi to a shared folder from my Windows 7 computer?
Let me know!
Cheers!
Josh.
  • John_H
    John_H over 12 years ago
    I think that the easiest way of telling what model you have is to look for holes for mounting screws. The first version didn't have any, the later ones do.
  • martijnl
    martijnl over 12 years ago
    A) take a look here: http://elinux.org/RPi_HardwareHistory
    B) install samba.. Small howto: http://simonthepiman.com/how_to_setup_windows_file_server.php
    Hope this helps a bit image
  • josh_j
    josh_j over 12 years ago in reply to John_H
    Mine doesn't have mounting holes on it so I guess it's model A?
  • josh_j
    josh_j over 12 years ago in reply to martijnl
    Is there a way to tell by what chip is on the board?
  • guzunty
    guzunty over 12 years ago in reply to josh_j
    No, it means it is an older Model 'B'.
    Model As have mounting holes but no ethernet jack and only one USB connector (instead of two one above the other).
  • josh_j
    josh_j over 12 years ago in reply to guzunty
    Let me guess, that model didn't have a lot of ram on it right? Like the 256MB models?
  • guzunty
    Which chip are you asking about? The SystemOnChip (the processor plus a lot of other cool stuff built in) is the same on all Pi's. It is a Broadcom BCM2835.
    The memory chip can vary by model. Some have Hynix and some Samsung. My older Model B Pi has Samsung memory (I believe all the older ones did). Some of the other chips have also probably been substituted over time.
    You should take a look at http://elinux.org/RPi_Hub which should answer most of your questions.
    best,
    Derek
  • josh_j
    Mine has the Samsung chip in the middle of the board. Also I read some where that earlier models didn't have CAT5 and the USB Port was a single port. However mine has CAT5 and Two USB ports. I wish I could get CPU-G to install on my Pi but I keep running into errors about it not being able to get the repo from Github.
  • guzunty
    Yes, earlier Model B's had only 256 MB of RAM. Newer ones, 512MB. The memory size was not changed at the same time as the mounting holes were added if I recall correctly.
  • guzunty
    guzunty over 12 years ago in reply to guzunty
    No you're thinking of the Model A. It's confusing. The Model B came out first, so all older boards had ethernet and two USB ports.
    Only later Model A boards have the ethernet and second USB socket removed. They are slightly cheaper, but the reason most people buy them is because they use quite a bit less current and so are better for battery powered projects.
