Raspberry Pi Forum Raspberry Pi used for a message board..
  • Replies 20 replies
  • Subscribers 707 subscribers
  • Views 3434 views
Trying to come up with an easy (cheap) way to set up a message board for our front office.  Just simply hooked up to a tv to display curren information.  Is Raspberry Pi a good means to do this?
  • guzunty
    guzunty over 12 years ago
    Digital signage is one application the Pi is certainly very well suited for, yes.
    e14 Contributor over 12 years ago in reply to guzunty
    Would the Pi + Advanced Bundle with Media Center do the trick?
  • guzunty
    guzunty over 12 years ago in reply to e14 Contributor
    That very much depends on your requirements and your budget. :-)
    You could get away with a Pi, Flatscreen TV and ethernet cable/wi-fi dongle and nothing else depending on what you want to do.
    With just that would you just basically get text on the screen?
  • guzunty
    guzunty over 12 years ago in reply to guzunty
    Also, can you post a link to the bundle you referred to? I don't see it on the Farnell site.
    If we can see the components you are proposing to buy we can help you better.
  • guzunty
    Nope, you'll get the full HDMI graphics experience. :-)
    Let us know more about what you want to do and how you much time and experience you have with setting up a linux system. I'll tailor my suggestions to that.
  • guzunty
    Here's a list of questions for you:
    - Where will this display be sited?
    - What kind information do you want to display?
    - Is the information to change frequently or infrequently?
    - If frequently, does it need to change automatically?
    - If frequent and/or automatic, Is there Wi-Fi or wired ethernet available at the proposed site?
    I'll add more as I think of them.
    Looking at displaying something like a Power Point presentation.  It would be displayed on a flat panel TV.  Updated weekly.  Not a lot of linux experience.
  • guzunty
    With a weekly update, you could maybe get away with just updating it by changing the SD card.
    The Pi will run Open Office which will display your PowerPoint presentations, though you need to be aware that the rendering is not 100% faithful.
    You may need to be patient and learn which PowerPoint techniques work well and which do not.
    In that case, you just need a Pi, a TV an SD card and a power supply. A keyboard can be borrowed to set the Pi up, but you don't need one continuously.
    You can of course buy a complete accessory bundle, but the above is all you really need. You'll also need a VESA mount if its going up on a wall, but I assume you've got the mechanical side of things under control and we just need to look at the software.
    How big are the PowerPoint presos?
    Will pretty much any wireless keyboard work?
