Raspberry Pi Forum Can't get values using analogRead with Chipkit Pi
  • Subscribers 705 subscribers
  • Views 534 views
I can't seem to get any values from any of the analog pins on the Chipkit Pi.  I will only get a 0 value if something is connected.  I'm using a 100K pot to test.  Using a volt meter, I can see that I'm putting 0 to 3.3 volts into the analog pin, but I don't get any value from analogRead.
I've tried analogRead(0) (I get a reading of 0) and analogRead(A0) (I get a constant reading of around 635). I've also tried other analog pins with the same result.
The digital pins work OK.
Am I missing something?
Thanks.
    int sensorPin = A0;
    int sensorValue = 0;
    void setup(){
         Serial.begin(9600);
    void loop(){
         sensorValue = analogRead(sensorPin);
         Serial.println(sensorValue);
         delay(1000);
  • lbittner
    lbittner over 12 years ago
    Hi Gregory,
    Thanks for your question! If you have any other questions re: the chipKIT Pi, please ask our chipKIT Pi expert, Tom Devine. He's on the site to answer chipKIT Pi questions through November 1: Want Help with Your chipKITTm Pi? Get AnswersTom Devine Through Nov. 8th!
    Lauren Bittner,
    element14 Global Community Marketing Manager
  • lbittner
    lbittner over 12 years ago in reply to e14 Contributor
    Hi Chris,
    Thanks for your question! If you have any questions or observations re: the chipKIT Pi, please ask our chipKIT Pi expert, Tom Devine. The link to his event is in my response to Gregory.
    Best,
    Lauren
