Raspberry Pi Forum [SOLVED] NOOBS not running on composite
  • Subscribers 703 subscribers
  • Views 1044 views
Hi Folk,
here I try in englisch http://www.element14.com/community/thread/28588/l/noobs-l%C3%A4uft-nicht-am-composite-anschlu%C3%9F-was-tun
I bought some Raspberry Pi 8GB SD card pre-installed with NOOBS . I though this should be the best for dummies, because I'm a raspberry pi starter. But now i have no imageon my TV (haveonly old TV withcomposite). The cable I use are ok. Used the cable from my dvd. After changig back the cable to dvd the dvd still works.
I read  http://www.element14.com/community/message/79100/l/composite-video-out-problem#79100, that I should change /boot/config.txt but I couldnot find the fileon the SD.
I hope the raspberry pi isnotdefect. What can I do to get it runonmy tv
Thank for any hint comming.
Regards
    Element14User
    Hi E14 User, Here is an abstract form the NOOBs documentation. Display Mode Selection: By default, NOOBS will output over HDMI at your display's preferred resolution, even if no HDMI display is connected. If you do not see any output on your HDMI display or are using the composite output, press 1, 2, 3 or 4 on your keyboard to select HDMI preferred mode, HDMI safe mode, composite PAL mode or composite NTSC mode respectively. https://github.com/raspberrypi/noobs/blob/master/README.md#about Hope this helps :)
    Hallo Chris,
    super image. Now I can see the menu, thank you for the link. I didn't find it.
    Thank you very much.
      Element14User
  • davidsg33k
    davidsg33k over 12 years ago in reply to e14 Contributor
    Thank you,
    the 1 2 3 4 buttons on the keyboard did the trick..   #4 here in USA.
    thanks for the help.
