Raspberry Pi Forum Is it possible to install Noobs on raspberry pi without a display and keyboard?
  • Replies 8 replies
  • Subscribers 678 subscribers
  • Views 1275 views
  • raspberrypi
babusingh9211
babusingh9211 over 12 years ago
I don't have a USB keyboard and any display device.
I only have a Raspberry Pi model 2 and a memory card.
Is there any possibilities to install use noobs.
like using Raspbian first time using SSH mode..
    HDMI connection into a monitor/TV and a USB mouse...
    You could use a common TV connected to RCA output, and select a key during boot to force that output. Off course, you need a keyboard to select the key. Or you could install NOOBS once with keyboard and input, select SSH, dhcp, etc, and the do image copies from that installation.
  • hawkeyethehacker
    hawkeyethehacker over 12 years ago
    In simple what the above is saying is that for the initial setup you will need a keyboard and mouse.
    It would be nice to see a headless multi distro image sometime soon.
    Former Member over 12 years ago in reply to hawkeyethehacker
    Just a mouse is enough, no need for a keyboard... image And everybody has a mouse... image
    shabaz over 12 years ago
    Hi Sumit,
    To summarize, as people have mentioned, today the 'NOOBs' software image does require a display (either HDMI or RCA/phono style connector) and some form of input (USB keyboard and/or mouse, possibly both). If you're using the RCA (phono style) connector, then a key needs pressing to enable the display, so then a keyboard is mandatory.
    After the initial install/config, you can discard the display and input devices, and use SSH as you wish.
  • saurocksall
    saurocksall over 12 years ago in reply to shabaz
    Thanks Shabaz,
    I was also wondering that glad to know it can be done with out a monitor...
    shabaz over 12 years ago in reply to saurocksall
    Hi Saurabh,
    Thanks, yes it is a little annoying that a monitor is initially needed,
    but afterwards it can be removed and used like any other server, just using the network to
    access it with SSH.
  • kushrami
    kushrami over 10 years ago
    i have posted the detailed setup of raspberry pi without screen,mouse and keyboard to this link u can refer it.....
    https://kushrami.wordpress.com/2015/01/22/how-to-start-raspberry-pi-without-screen/
