Raspberry Pi Forum Working with Raspberry and Whatsapp
  • Subscribers 702 subscribers
  • Views 820 views
  • rasberry
  • whatsapp
So far I could try sending messages from Whatsapp to raspberry, raspberry sending messages from a cell phone and I need to do two tasks at once.
Someone has information, as well to keep the conversation closes after 3 min
  • packetgeek
    packetgeek over 12 years ago
    Not sure what you're looking for but I think the connection loss (after 3 minutes) might be related to your cell phone carrier rather than WhatsApp.  That or (since WhatsApp appears to be customized XMPP service), there could be an automatic activity timeout.  I'm just guessing though.
    e14 Contributor over 12 years ago in reply to packetgeek
    I'm controlling devices from Whatsapp and there comes a time that I get a message on the console terminal is closed the conversation, since there no longer receives more messages
    use python , import socket,time
    every 2 minutes  connect to the whatsapp port, send foo and close. That should keep it alive indefinitely.
  • iagorubio
    iagorubio over 12 years ago in reply to e14 Contributor
    Hi Alejandro,
    Looks like your problem - correct me if I am wrong - it's somewhat your console is being closed.
    If you are connected to that console through ssh you may end up with a message saying something like "connection closed by peer" after some time.
    If that is your problem, it happens because ssh closes the connection after some time of inactivity.
    You can order your client to "ping" the ssh server once in a while to avoid it to close the connection for inactivity.
    It's a setting in your ~/.ssh/config file called ServerAliveInterval and it's a number of seconds.
    ServerAliveInterval 60
    Will ping the server each 60 seconds. That will maintain the ssh console open and working.
    From the ssh_config manual page:
         ServerAliveInterval
                 Sets a timeout interval in seconds after which if no data has
                 been received from the server, ssh(1) will send a message through
                 the encrypted channel to request a response from the server.  The
                 default is 0, indicating that these messages will not be sent to
                 the server.  This option applies to protocol version 2 only.
    If you don't have that file and have to create it, remember to make it only readable by yourself, because ssh complains if the file is world readable.
    echo ServerAliveInterval 60 >>  ~/.ssh/config
    chmod 600 ~/.sshd/config
    I added my Whatsapp account powered by Raspberry to a group. The result I got a Trace back problem. The group was deleted the. Can someone help me resolve it ?
