Raspberry Pi Forum Raspberry Pi component map
  • Subscribers 702 subscribers
  • Views 880 views
  • raspberrypi
  • component
Hi guys, after a big lot of work and time, i got mapped virtually all components of raspberry pi(rev2) in a single image, 25 of them you can click and will open the datasheet, you can see values of all capacitors and resistors, some of components have some information, its the 0.1 version, more improvements in future.
This website uses css3 transform and some browsers lack this feature, therefore we recommend recent versions of Firefox or Chrome until improvements in the code to support old browsers.
Is already useful to me and i hope you all enjoy http://raspmap.tsar.in
    michaelkellett over 12 years ago
    Very nice - rather than than some of the 3D visualisation that PCB CAD systems have now it would be nice if they could automatically make maps like this - I spend far too much time trying to work which bit is which on complex boards (sometimes even ones I designed myself !).
    If you had some spare time it would be even better if the GPIO pins had individual mapping.
  • gdstew
    gdstew over 12 years ago in reply to michaelkellett
    Does this help ?
    GPIO pins used for hardware on board
    GPIO0, GPIO1      SDA0, SCL0 on camera interface connector
    GPIO5                  CAM_CLK on camera interface connector
    GPIO6                   LAN_RUN to N_RESET pin of LAN9512
    GPIO16                 STATUS_LED_N to status LED cathode
    GPIO21                 CAM_GPIO to camera interface connector
    GPIO40, GPIO45    PWM0_OUT, PWM1_OUT to R/L audio output circuit
    GPIO46                 HDMI_HP0_P on HDMI connector
    GPIO47 - GPIO53   SD_CARD_DET, SD_CLK_R, SD_CMD_R, SD_DATA0_R, SD_DATA1_R,
                                 SD_DATA2_R, SD_DATA3_R on SD-card interface connector
    User programmable GPIO pins
    GPIO2, GPIO3       SDA1, SCL1 on General Purpose I/O connector P1 (26 pin)
    GPIO4                   GPIO_GCLK on General Purpose I/O connector P1 (26 pin)
    GPIO7 - GPIO11    SPI_CE1_N, SPI_CE0_N, SPI_MISO, SPI_MOSI, SPI_SCLK on
    GPIO12, GPIO13    Not connected
    GPIO14, GPIO15    TXD0, RXD0 on General Purpose I/O connector P1 (26 pin)
    GPIO17, GPIO18    GPIO_GEN0, GPIO_GEN1 on General Purpose I/O connector P1  (26 pin)
    GPIO19, GPIO20    Not connected
    GPIO22 - GPIO25   GPIO_GEN3, GPIO_GEN4, GPIO_GEN5, GPIO_GEN6 on General Purpose
    GPIO26                  Not connected
    GPIO27                  GPIO_GEN2 on General Purpose I/O connector P1 (26 pin)
    GPIO28 - GPIO31   GPIO_GEN7, GPIO_GEN8, GPIO_GEN9, GPIO_GEN10 on General
                                  Purpose I/O connector P5 (8 pin)
    GPIO32 - GPIO39   Not connected
    GPIO41 - GPIO44   Not connected
  • iagorubio
    iagorubio over 12 years ago
    Great job Alex.
    Thanks for taking your time to make it and share it with us.
    mcb1 over 12 years ago in reply to iagorubio
    Nice work.
    Thanks everybody, GPIO pins individual mapping in the next version image
    0.2 minor version released, simple individual mapping of GPIO, close image of SMSC chip, about page.
