Raspberry Pi Forum Wolfson and MPD  working
  • Replies 45 replies
  • Subscribers 684 subscribers
  • Views 5017 views
superpat
superpat over 12 years ago
I installed MPD onto the provided Wolfson Audio distribution, running it headless,  console via ssh.
I copied the provided demo flac files to the mpd music directory.
I ran alsamixer and wound up the digital i/p's and outputs.
controlling  MPD with the GMPC client on my LInux desktop
96Kbps flacs are playing  superbly, output  lineout  and into my desktop audio amp and speakers,
Next I will set mpd to get music from my NAS using nfs, which will be interesting, as this tends load the Pi system and  cause problems with the Pi and usb dacs!
cheers
P
  • superpat
    superpat over 12 years ago in reply to shabaz
    Hi Shabaz,
    Explain this then:-
    http://www.datasheetarchive.com/PCM5102-datasheet.html
    Texas Instruments Cross Reference Results
    Texas Instruments Part   Industry Part                  Manufacturer               Type                                          Comment                 Description
    PCM5102 BuyWM8521 BuyWolfson MicroelectronicsLoad support is 1000 ohms vs. Cirrus 5000 ohms. PCM5102 supports up to 10 end products in parallel112dB Stereo DAC with 2VRMS output and Integrated Audio PLL
    I always thought there was some wheeling and dealing between Burr Brown and Texas and Wolfson over the DAC design!
    regards
    Patrick
    shabaz over 12 years ago in reply to superpat
    As stated earlier:
    From a hardware point of view it won't have effects like skip or anything like the USB ones you've experienced. The interface is very different, and is at a determined rate with no contention from other devices like USB. It is a dedicated audio interface.
    There may well be software or driver, or other issues, but I'm afraid I can't help with that. Perhaps someone else can.
    Two part numbers are on the one website, agreed (and just to avoid confusion - neither of these part numbers have anything to do with the
    Wolfson audio card!), but they are not similar parts. For any part (Wolfson audio or not) it can be confirmed by looking at the manufacturer data sheets.
    Former Member over 12 years ago in reply to superpat
    I don't think I've read about anyone having usb bandwidth issues after switching from usb dacs to i2s. Shouldn't all the success hifberry users have also be true for wolfson card users in this respect?
    I'm not sure if you mentioned this or not, but were you able to play 24/192 files through usb dacs without glitches when the files were on the sd card?
    Former Member over 11 years ago in reply to superpat
    I have just played a bunch of 96 and 192 KHz/24bit tracks with the lxmusic player, average bit rate 5 111 Kbps.
    The flac files reside on another RPi that I have NFS-mounted.
    Both Pis use USB hard disks, I only have a boot partition on the SD cards.
    I experience no clicks or pauses whatsoever. When playing 192KHz tracks, the nfs server processes use ~9% CPU, at 96KHz they use less than 0.1%
    Ragnar
    I'm trying to get my wolfson card going-but I'm terribly struck...
    What i did:
    - install 2014-01-07-wheezy-raspbianW.zip
    - expandet the FS
    - updated
    - sudo apt-get install lxmusic xmms2 xmms2-plugin-all volumeicon-alsa mpg123 mplayer
    startx, and the musicplayer:
    there is no sound, altough i tried all output sound-systems..
    at the bash
    i get errors when i try to play some music directly...
    Any hint how to get it working?
    Former Member over 11 years ago in reply to Former Member
    You remembered to run the appropriate use case script (Playback_to...) first?
    "-updated"
    Updated what? It's possible you have updated the kernel, and now have an official Foundation kernel without the Wolfson drivers.
    The command
    cat /proc/version
    should return "Linux version 3.10.25_Wolfson+ (ragnar@kernel)..."
    If it doesn't, try
    sudo cp /boot/kernel_wolfson.img /boot/kernel.img
    and reboot.
    Ragnar
    of course i replaced the kernel after the update... image
    cat /proc/version
    Linux version 3.10.25_Wolfson+ (ragnar@kernel) (gcc version 4.7.1 20120402 (prerelease) (crosstool-NG 1.15.2) ) #1 PREEMPT Fri Feb 21 00:03:14 CET 2014
    yes I did....
    pi@raspberrypi ~ $ /home/pi/use_case_scripts/Playback_to_All.sh
    numid=151,iface=MIXER,name='HPOUT2 Digital Switch'
      ; type=BOOLEAN,access=rw------,values=2
      : values=on,on
    numid=389,iface=MIXER,name='HPOUT2L Input 1'
      ; type=ENUMERATED,access=rw------,values=1,items=99
      ; Item #0 'None'
      ; Item #1 'Tone Generator 1'
      ; Item #2 'Tone Generator 2'
      ; Item #3 'Haptics'
      ; Item #4 'AEC'
      ; Item #5 'Mic Mute Mixer'
      ; Item #6 'Noise Generator'
    I always get an error:
    mpd
    Failed to bind to '[::]:6600': Failed to create socket: Address family not supported by protocol
    "Failed to bind to '[::]:6600'"
    It looks like mpd is trying to use IPv6.
    Could you post your mpd.conf file?
    Ragnar
    sorry took a few days to get back to life...
    To make sure, that I made no mistake i started from beginning...
    - install (2014-01-07-wheezy-raspbianW.zip)
    - update
    # sudo apt-get update
    # sudo apt-get upgrade
    # sudo rpi-update
    # sudo reboot
    - replace kernel and check it:
    pi@raspberrypi ~ $ cat /proc/version
    - install Music-progr's:
    pi@raspberrypi ~ $ sudo apt-get install lxmusic xmms2 xmms2-plugin-all volumeicon-alsa mpg123 mplayer
    - use use-case-script
    pi@raspberrypi ~ $ sudo /home/pi/use_case_scripts/Playback_to_All.sh
    which gives me an output (I removed the lines with the ";" in front  to make the list shorter ;-)
      : values=on,on
      : values=15
    numid=120,iface=MIXER,name='HPOUT2L Input 1 Volume'
      ; type=INTEGER,access=rw---R--,values=1,min=0,max=48,step=0
      : values=32
      | dBscale-min=-32.00dB,step=1.00dB,mute=0
    numid=385,iface=MIXER,name='HPOUT2R Input 1'
      : values=16
    numid=124,iface=MIXER,name='HPOUT2R Input 1 Volume'
      : values=32
    when i start mplayer with a music file I get:
    pi@raspberrypi ~ $ mplayer /media/cross.mp3
    MPlayer svn r34540 (Debian), built with gcc-4.6 (C) 2000-2012 MPlayer Team
    mplayer: could not connect to socket
    mplayer: No such file or directory
    Failed to open LIRC support. You will not be able to use your remote control.
    Playing /media/cross.mp3.
    libavformat version 53.21.1 (external)
    Mismatching header version 53.19.0
    Audio only file format detected.
    Clip info:
    Title:
    Artist:
    Album:
    Year:
    Comment:
    Genre: Unknown
    Load subtitles in /media/
    Requested audio codec family [mpg123] (afm=mpg123) not available.
    Enable it at compilation.
    Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
    libavcodec version 53.35.0 (external)
    Mismatching header version 53.32.2
    AUDIO: 48000 Hz, 2 ch, floatle, 320.0 kbit/10.42% (ratio: 40003->384000)
    Selected audio codec: [ffmp3float] afm: ffmpeg (FFmpeg MPEG layer-3 audio)
    AO: [pulse] Init failed: Connection refused
    Failed to initialize audio driver 'pulse'
    [AO_ALSA] alsa-lib: pcm_hw.c:1293:(snd_pcm_hw_open) open '/dev/snd/pcmC0D0p' failed (-16): Device or resource busy
    [AO_ALSA] Playback open error: Device or resource busy
    Failed to initialize audio driver 'alsa'
    [AO SDL] Samplerate: 48000Hz Channels: Stereo Format floatle
    [AO SDL] using aalib audio driver.
    [AO SDL] Unsupported audio format: 0x1d.
    [AO SDL] Unable to open audio: No available audio device
    Failed to initialize audio driver 'sdl:aalib'
    Could not open/initialize audio device -> no sound.
    Audio: no sound
    Video: no video
    Exiting... (End of file)
    So, I think there is a configuration problem of mplayer or alsa....
    Any hint?
