Raspberry Pi Forum Wolfson and MPD  working
  • Replies 45 replies
  • Subscribers 684 subscribers
  • Views 5018 views
superpat
superpat over 12 years ago
I installed MPD onto the provided Wolfson Audio distribution, running it headless,  console via ssh.
I copied the provided demo flac files to the mpd music directory.
I ran alsamixer and wound up the digital i/p's and outputs.
controlling  MPD with the GMPC client on my LInux desktop
96Kbps flacs are playing  superbly, output  lineout  and into my desktop audio amp and speakers,
Next I will set mpd to get music from my NAS using nfs, which will be interesting, as this tends load the Pi system and  cause problems with the Pi and usb dacs!
cheers
P
    Former Member over 11 years ago in reply to Former Member
    "Device or resource busy"
    Something else is using the sound card.
    Try this to find out what:
    fuser -uv /dev/snd/pcmC0D0p
    "sudo /home/pi/use_case_scripts/Playback_to_All.sh"
    Don't use sudo to run the use case scripts.
    Ragnar
    pi@raspberrypi ~ $ fuser -uv /dev/snd/pcmC0D0p
                         BEN.        PID ZUGR.  BEFEHL
    /dev/snd/pcmC0D0p:   pi         2342 F...m (pi)xmms2d
    btw my alsa-base:
    # autoloader aliases
    install sound-slot-0 /sbin/modprobe snd-card-0
    install sound-slot-1 /sbin/modprobe snd-card-1
    install sound-slot-2 /sbin/modprobe snd-card-2
    install sound-slot-3 /sbin/modprobe snd-card-3
    install sound-slot-4 /sbin/modprobe snd-card-4
    install sound-slot-5 /sbin/modprobe snd-card-5
    install sound-slot-6 /sbin/modprobe snd-card-6
    install sound-slot-7 /sbin/modprobe snd-card-7
    # Cause optional modules to be loaded above generic modules
    install snd /sbin/modprobe --ignore-install snd && { /sbin/modprobe --quiet snd-ioctl32 ; /sbin/modprobe --quiet snd-seq ; : ; }
    install snd-rawmidi /sbin/modprobe --ignore-install snd-rawmidi && { /sbin/modprobe --quiet snd-seq-midi ; : ; }
    install snd-emu10k1 /sbin/modprobe --ignore-install snd-emu10k1 && { /sbin/modprobe --quiet snd-emu10k1-synth ; : ; }
    # Keep snd-pcsp from beeing loaded as first soundcard
    options snd-pcsp index=-2
    # Keep snd-usb-audio from beeing loaded as first soundcard
    options snd-usb-audio index=-2
    # Prevent abnormal drivers from grabbing index 0
    options bt87x index=-2
    options cx88_alsa index=-2
    options snd-atiixp-modem index=-2
    options snd-intel8x0m index=-2
    options snd-via82xx-modem index=-2
    OK, so the xmms2 daemon is running. Probably some other player has started it. E.g. LXMusic is an xmms2 client.
    Do you have any other player programs running? Close them.
    If not, kill it. kill 2342
    Ragnar
    OK, the fisrt step is done...
    Now I get:
    pi@raspberrypi ~ $ mplayer /media/lady.mp3
    MPlayer svn r34540 (Debian), built with gcc-4.6 (C) 2000-2012 MPlayer Team
    mplayer: could not connect to socket
    mplayer: No such file or directory
    Failed to open LIRC support. You will not be able to use your remote control.
    Playing /media/lady.mp3.
    libavformat version 53.21.1 (external)
    Mismatching header version 53.19.0
    Audio only file format detected.
    Clip info:
    Title:
    Artist:
    Album:
    Year:
    Comment:
    Genre: Unknown
    Load subtitles in /media/
    Requested audio codec family [mpg123] (afm=mpg123) not available.
    Enable it at compilation.
    Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
    libavcodec version 53.35.0 (external)
    Mismatching header version 53.32.2
    AUDIO: 48000 Hz, 2 ch, floatle, 320.0 kbit/10.42% (ratio: 40004->384000)
    Selected audio codec: [ffmp3float] afm: ffmpeg (FFmpeg MPEG layer-3 audio)
    waitpid(): No child processes
    AO: [pulse] Init failed: Internal error
    Failed to initialize audio driver 'pulse'
    [AO_ALSA] Format floatle is not supported by hardware, trying default.
    AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
    Video: no video
    Starting playback...
    A:   0.0 (00.0) of 216.0 (03:36.0) ??,?%
    (here the pi strucks until I press ^C twice)
    As I mentioned aboce, I startet new - so I didn't install mpd / mpc: ist that a problem? should I?
    I have the exact same output as you from mplayer. Except mine plays the file...
    The two lines you have bolded can be ignored, they are from when mplayer tries to find an infra-red remote control receiver.
    What is the output from aplay -l and aplay -L ?
    What happens if you try to play a wav file with aplay -vv file.wav?
    EDIT: No don't install mpd/mpc yet. That will only complicate matters.
    I don't have them installed.
    Ragnar
    pi@raspberrypi ~ $ aplay -l
    **** Liste der Hardware-Geräte (PLAYBACK) ****
    Karte 0: sndrpiwsp [snd_rpi_wsp], Gerät 0: WM5102 AiFi wm5102-aif1-0 []
      Sub-Geräte: 1/1
      Sub-Gerät #0: subdevice #0
    Karte 1: ALSA [bcm2835 ALSA], Gerät 0: bcm2835 ALSA [bcm2835 ALSA]
      Sub-Geräte: 8/8
      Sub-Gerät #1: subdevice #1
      Sub-Gerät #2: subdevice #2
      Sub-Gerät #3: subdevice #3
      Sub-Gerät #4: subdevice #4
      Sub-Gerät #5: subdevice #5
      Sub-Gerät #6: subdevice #6
      Sub-Gerät #7: subdevice #7
    pi@raspberrypi ~ $ aplay -L
    null
        Discard all samples (playback) or generate zero samples (capture)
    sysdefault:CARD=sndrpiwsp
        snd_rpi_wsp,
        Default Audio Device
    sysdefault:CARD=ALSA
        bcm2835 ALSA, bcm2835 ALSA
    aplay -vv /media/cross.mp3
    Wiedergabe: Rohdaten '/media/cross.mp3' : Unsigned 8 bit, Rate: 8000 Hz, mono
    aplay: set_params:1081: Sample-Format nicht unterstützt
    Available formats:
    - S16_LE
    - S32_LE
    and the same on a radio stream
    pi@raspberrypi ~ $ mplayer http://stream.srg-ssr.ch/m/rsp/mp3_128
    Playing http://stream.srg-ssr.ch/m/rsp/mp3_128.
    Resolving stream.srg-ssr.ch for AF_INET...
    Connecting to server stream.srg-ssr.ch[193.218.104.243]: 80...
    Name   : Radio Swiss Pop
    Genre  : Pop Music
    Website: http://www.radioswisspop.ch
    Public : no
    Bitrate: 128kbit/s
    Cache size set to 320 KBytes
    Cache fill:  2.50% (8192 bytes)
    ICY Info: StreamTitle='Eurythmics - I Saved The World Today';
    Cache fill: 15.00% (49152 bytes)
    AUDIO: 44100 Hz, 2 ch, floatle, 128.0 kbit/4.54% (ratio: 16000->352800)
    AO: [pulse] Init failed: Connection refused
    AO: [alsa] 44100Hz 2ch s16le (2 bytes per sample)
    Video: no video
    A:   0.0 (00.0) of 0.0 (unknown) ??,?% 24%
    Here is the same: no sound, and the programm strucks showing always A:   0.0 (00.0) of 0.0 (unknown) ??,?% 24%
    until I press Ctrl-C
    MPlayer interrupted by signal 2 in module: enable_cache
    MPlayer interrupted by signal 2 in module: play_audio
    Not mp3.
    Ragnar
    mplayer /media/ex.WAV
    Playing /media/ex.WAV.
    Opening audio decoder: [pcm] Uncompressed PCM audio decoder
    AUDIO: 11025 Hz, 1 ch, u8, 88.2 kbit/100.00% (ratio: 11025->11025)
    Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
    [AO_ALSA] Format u8 is not supported by hardware, trying default.
    [AO_ALSA] alsa-lib: pcm_hw.c:326:(snd_pcm_hw_hw_params) SNDRV_PCM_IOCTL_HW_PARAMS failed (-22): Invalid argument
    [AO_ALSA] Unable to set hw-parameters: Invalid argument
    Failed to initialize audio driver 'alsa'
    [AO SDL] Samplerate: 11025Hz Channels: Mono Format u8
    [AO SDL] using aalib audio driver.
    [AO SDL] Unable to open audio: No available audio device
    Failed to initialize audio driver 'sdl:aalib'
    Could not open/initialize audio device -> no sound.
    Audio: no sound
    Video: no video
    Exiting... (End of file)
    pi@raspberrypi ~ $ aplay -vv ex.WAV
    ex.WAV: Datei oder Verzeichnis nicht gefunden
    pi@raspberrypi ~ $ aplay -vv /media/ex.WAV
    Wiedergabe: WAVE '/media/ex.WAV' : Unsigned 8 bit, Rate: 11025 Hz, mono
    Available formats:
    - S16_LE
    - S32_LE
    pi@raspberrypi ~ $
    Could it be, that the problem is in an conf. file?
    eg. alsa, or mplayer?
    OK, I have managed to replicate the error.
    If I run the Reset_paths.sh script to disconnect all outputs, my mplayer stalls like yours do.
    What if you try to run the Playback_to_Lineout.sh or SPDIF_playback.sh  script first?
    EDIT: The wav file you tried with is the wrong format. Must be at least 32kHz and 2 channels.
    Ragnar
