Raspberry Pi Forum Wolfson and MPD  working
  • Replies 45 replies
  • Subscribers 683 subscribers
  • Views 5170 views
superpat
superpat over 12 years ago
I installed MPD onto the provided Wolfson Audio distribution, running it headless,  console via ssh.
I copied the provided demo flac files to the mpd music directory.
I ran alsamixer and wound up the digital i/p's and outputs.
controlling  MPD with the GMPC client on my LInux desktop
96Kbps flacs are playing  superbly, output  lineout  and into my desktop audio amp and speakers,
Next I will set mpd to get music from my NAS using nfs, which will be interesting, as this tends load the Pi system and  cause problems with the Pi and usb dacs!
cheers
P
    Former Member over 11 years ago in reply to Former Member
    pi@raspberrypi ~ $ aplay -vv /media/aaron.wav
    Wiedergabe: WAVE '/media/aaron.wav' : Signed 16 bit Little Endian, Rate: 44100 Hz, stereo
    Soft volume PCM
    Control: Master
    min_dB: -51
    max_dB: 0
    resolution: 256
    Its setup is:
      stream       : PLAYBACK
      access       : RW_INTERLEAVED
      format       : S16_LE
      subformat    : STD
      channels     : 2
      rate         : 44100
      exact rate   : 44100 (44100/1)
      msbits       : 16
      buffer_size  : 22052
      period_size  : 5513
      period_time  : 125011
      tstamp_mode  : NONE
      period_step  : 1
      avail_min    : 5513
      period_event : 0
      start_threshold  : 22052
      stop_threshold   : 22052
      silence_threshold: 0
      silence_size : 0
      boundary     : 1445199872
    Slave: Hardware PCM card 0 'snd_rpi_wsp' device 0 subdevice 0
    Its setup is:
      stream       : PLAYBACK
      access       : MMAP_INTERLEAVED
      format       : S16_LE
      subformat    : STD
      channels     : 2
      rate         : 44100
      msbits       : 16
      buffer_size  : 22052
      period_size  : 5513
      tstamp_mode  : NONE
      period_step  : 1
      avail_min    : 5513
      period_event : 0
      silence_size : 0
      appl_ptr     : 0
      hw_ptr       : 0
    ##############+                                    | 26%
    the same: at the end the pi strucks until I ctrl-C
    Yes, that is what happens for me too, if I haven't set up any playback output on the card.
    What if you try to run the Playback_to_Lineout.sh or SPDIF_playback.sh script first?
    Ragnar
    i did! as you recomended - of course!! ;-)
    pi@raspberrypi ~ $ /home/pi/use_case_scripts/Reset_paths.sh >reset.txt
    amixer: Cannot find the given element from control hw:0
    pi@raspberrypi ~ $ /home/pi/use_case_scripts/Playback_to_Lineout.sh >lin.txt
    do you need the output files?
    I get the " Cannot find the given element from control hw:0" too. They forgot to remove a line from the script.
    What is output from
    amixer -Dhw:0 cget name='HPOUT2L Input 1'
    and
    amixer -Dhw:0 cget name='HPOUT2R Input 1' ?
    Only the last line is important, should be
    values=15 and
    values=16
    If they are, the card is setup to playback to the Line Out jack and the players should be able to play.
    Ragnar
      : values=15
    and
    : values=16
    so this should be correct....
    But while strucks the player instead of playing image
    do you think it may help if I reinstall mplayer with -force?
    You could try, but I'm not sure it will help.
    To find out if  it will play at all, try to play back to the Pi's built-in audio:
    mplayer -ao alsa:device=hw=1.0 somefile.mp3
    I'm getting short of ideas...
    Ragnar
    YES!
    it plays out of the PI-Jack...
    btw how is the command to switch back - maybee it works now
    so maybee I will have just to return the card and get an "simple" DAC...
    You don't have to switch it back.
    -ao alsa:device=hw=1.0 tells mplayer to use hardware card number 1 temporarily.
    By default it will use card number 0 - the Wolfson.
    I'm starting to think that your Wolfson card might be broken.
    Ragnar
    but if I try to play via the wolfson card the mplayer gets strucked...
    You think this might happen because of a defect hardware?
    Yes, it's quite possible.
    Ragnar
