Raspberry Pi Forum Any galvanic isolation of the electrical SPDIF out?
  • Subscribers 703 subscribers
  • Views 598 views
  • galvanic
  • isolation
  • raspeberry_pi_accessories
  • spdif
An impressive little board with great flexibility at this price point. Does anyone know if it has galvanic isolation of the electrical SPDIF out?
  • pmiller056
    pmiller056 over 12 years ago
    Looking at the circuit diagram, NO.
    Galvanic isolation will be provided with an optical connection. AFAIK you can get coax to optical SPDIF
    converters reasonably cheaply online. If you are feeling adventurous, there is info available online to make
    your own.
    If you are worried about earth/ground loops, you could operate you raspi system from a double insulated power
    supply that only has a 2 wire power lead or unearthed mains connection. If the power supply you are using has
    an earth/ground connection or a 3 wire power lead, DO NOT disconnect the earth/ground connection - you may
    make the power supply or connected equipment dangerous to use.
    Peter
    e14 Contributor over 12 years ago in reply to pmiller056
    Thank you for looking this up. It did look like it didn't have it on the board. I was planning on using this as a transport for hifi audio, but going via optical is not an option. I might still get it for another purpose, because it is highly versatile.
