Raspberry Pi Forum Benachrichtigung, wenn Briefkasten geöffnet wurde
  • Subscribers 676 subscribers
  • Views 666 views
Hallo zusammen,
wie könnte man seinen Wohnungsbriefkasten so modifizieren, dass er ein Signal an meinen Raspberry Pi sendet, wenn der Deckel vom Briefkasten geöffnet wurde. Ich wohne im zweiten Stockwerk und der Briefkasten befindet sich logischerweise am Hauseingang. Das Ganze sollte drahtlos funktionieren, da ich dort kein Kabel legen darf.
Ich würde das gerne selber bauen, wie kann man so etwas realisieren? Welche Teile kann man da empfehlen?
Grüße
  • Robert Peter Oakes
    Robert Peter Oakes over 11 years ago
    Do you have power available at the letter box or will you need to run with batteries ?
    Former Member over 11 years ago in reply to Robert Peter Oakes
    There is no power available. Is there any chance to run it with batteries? I'm not sure what components I need.
    Robert Peter Oakes over 11 years ago in reply to Former Member
    you could but the PI consumes about 500mA on its own, then you will have to add WIFI adapter, maybe a screen etc depending on your needs near the letterbox
    a better approach may be to use something like an Arduino or Launch Pad (Atmel vs TI) at the letterbox and use the PI in the apartment, the only issue being the range between them, how far is it (Line of sight)?, 30feet, 100 feet, more ?
    the Microcontrollers are able to run on significantly less power (Some of the TI modules go down into the uA range so almost any battery would last for weeks without re-charging
    do you have a way of securing your monitor device to prevent it getting stolen or exposed to the elements ?
    Peter
    That sounds very well, using the rpi at the apartment and microcontrollers at the letterbox. The range is about 13feet. There are some walls between them. The letterbox is inside the building and the cover can be accessed from outside.
    Could you recommend any components?
    Hallo Jure,
    Du könntest z.B. Sensoren von EnOcean nehmen:
    https://www.enocean.com/de/batterielose-funktechnologie/
    Ein Reciver am RasPi und fertig:
    https://www.enocean.com/de/enocean-pi/
    Als "Visualisierung" bzw. "Anzeige" könntest Du TTS mit einem Aktiv-Lautsprecher verwenden "Sie haben Post" image
    Viele Grüße,
    Christian
