Raspberry Pi Forum Is the rpiboot install method working with Ubuntu on Vmware?
  • Subscribers 683 subscribers
  • Views 1099 views
  • rpiboot
davorin
davorin over 11 years ago
Hello
Just unpacked my RPi dev kit and followed the blog instruction to load Debian onto internal eMMC flash...
Powering up the kit and connecting the USB slave port to PC doesn't reveal any USB device...nor in OSX or under Ubuntu in Vmware...
And yes, the jumper is set to "EN" (o;
Also switches USB cables...
If it should show up as a disk drive then even OSX would list this USB device under system profiler...
  • davorin
    Nope...also on a real machine with Ubuntu it doesn't work...
    Tried with two RPi dev kits...
    Endless syslog messages with:
    ug 15 13:58:53 nuc kernel: [711575.080415] usb 2-1: new full-speed USB device number 8 using xhci_hcd
    Aug 15 13:58:58 nuc kernel: [711580.078639] xhci_hcd 0000:00:14.0: Timeout while waiting for address device command
    Aug 15 13:58:59 nuc kernel: [711580.282714] usb 2-1: Device not responding to set address.
    Aug 15 13:58:59 nuc kernel: [711580.486496] usb 2-1: device not accepting address 8, error -71
    Aug 15 13:58:59 nuc kernel: [711580.598427] usb 2-1: new full-speed USB device number 9 using xhci_hcd
    Aug 15 13:59:04 nuc kernel: [711585.596550] xhci_hcd 0000:00:14.0: Timeout while waiting for address device command
    Aug 15 13:59:04 nuc kernel: [711585.800736] usb 2-1: Device not responding to set address.
    Aug 15 13:59:04 nuc kernel: [711586.004499] usb 2-1: device not accepting address 9, error -71
    Aug 15 13:59:04 nuc kernel: [711586.004614] hub 2-0:1.0: unable to enumerate USB device on port 1
    Former Member over 11 years ago in reply to davorin
    Hi there,
    Did you make any progress with this?  I'm having the same issue with CentOS 7 on an ASUS i7-4790K motherboard.
    J
    Former Member over 11 years ago in reply to Former Member
    I discovered more details about this issue on the raspberry pi forums, under the unfortunately titled "USBBoot on OSX".
    • Raspberry Pi • View topic - USBBoot on OSX
    TL;DR
    The compute module firmware has a bug that makes it not work for all USB3 hosts and many USB2.  The guaranteed way to make it work is with another Raspberry Pi.
    Finally, to follow up, after disabling Intel xHCI in the BIOS I was able to successfully use rpiboot with the raspberrypi compute module.
