Raspberry Pi Forum Camera in Raspi
  • Subscribers 684 subscribers
  • Views 523 views
  • raspberry-pi
Camera in Raspi
First I use command raspistill or raspivid -o and camera running ok. Then five days, i set up opencv, g++, i use command raspistill or raspivid -o, its take one photo or a video have some frames (don't have time video like set up time)...and after the screen LCD so dark and not display. I fix it use "sudo nano /boot/config.txt but its continue problems. Help me, please help me. Thank you
  • kidiccurus
    kidiccurus over 11 years ago
    First upnplug and plug back in the camera to check for a bad connection. If that fails I recommend completely wiping your SD card and reinstalling your os.
    Former Member over 11 years ago in reply to kidiccurus
    Today, I use command raspistill -o camera take photo ok, i think my power is bad when used along time. Thank you your answer for me.
  • kidiccurus
    kidiccurus over 11 years ago in reply to Former Member
    A good PSU is essential with a pi as it has to run USB as well as the pi itself. Try and aim for a PSU with at least 2 amps, preferably more.
    At least 2Amp. Thanks
  • kidiccurus
    That should be ok. If its working then it is not worth troubleshooting for now, but if it fails again please post so I can try and fix it.
