Raspberry Pi Forum Problems getting card to be detected
  • Subscribers 674 subscribers
  • Views 352 views
  • raspeberry_pi_accessories
I purchased a Wolfson Audio card for my Raspberry Pi about 6 months ago and have just gotten around to hooking it up but it appears the card is not being detected by the system.
I have downloaded the SD image from element14 and loaded it onto the Pi. Card is connected and lights up so appears to be powered up OK. System boots and functions fine other than detecting the card.
I believe these lines in the syslog relate to the issue. I have also linked the full syslog below.
[code]Jan  7 23:32:10 raspberrypi kernel: [    4.300931] snd-rpi-wsp snd-rpi-wsp.0: ASoC: CODEC wm5102-codec not registered
Jan  7 23:32:10 raspberrypi kernel: [    4.313058] snd-rpi-wsp snd-rpi-wsp.0: Failed to register card: -517
Jan  7 23:32:10 raspberrypi kernel: [    4.323996] platform snd-rpi-wsp.0: Driver snd-rpi-wsp requests probe deferral[/code]
Full syslog:
http://www.nl.com.au/temp/syslog.log
I have cleaned the contacts on both the Raspberry Pi and the Wolfson and checked it with a multimeter all connections on both GPIO and the P5 header seem fine.
Is there anything else to try or have I got myself a dud card?
Thanks in advance,
David
    You could try the card with some other software images that have the Wolfson card drivers built-in. Squeezeplug used to. it may still do, although I've lost track of whether it does or not now SqueezePlug .
    Volumio doesn't support the Wolfson natively, but there are custom builds of it that do Wolfson Audio card with Volumio : Unofficial Portings - Page 11
    If those work for you then it might suggest a problem with the Element14 image, or confirm your fear that you have a dud card.
