Raspberry Pi Forum Raspberry Pi Model A+ > Specs Released
  • Replies 14 replies
  • Subscribers 709 subscribers
  • Views 2791 views
  • raspbmc
  • raspi
  • a+
wallarug
wallarug over 11 years ago
See this article:  http://www.i-programmer.info/news/91-hardware/7956-new-raspberry-pi-a.html
They found a page on Element14's site that was later taken down.
What do you guys think?
  • wallarug
    wallarug over 11 years ago in reply to rew
    Sorry for not being clear.  I was on my phone and we all know that long messages on a small keyboard are time consuming.
    I was suggesting Number 3.  Doing the other two is IMPOSSIBLE (I am fully aware of that).  I remember on the Model B there was a pair of resistors which could be fitted to by-pass the USB chip.  If what your saying is true, then yes, you could not convert a B+ into an A+.  I am sure someone can investigate this later (or experiment).
    You can however still remove the surplus USB ports and create a 512 MB single/double USB Pi, but that would still be putting power into the USB chip (as you stated above).
    Adafruit Tutorial on how to do this (looks very sleek):  https://learn.adafruit.com/diet-raspberry-pi
  • rew
    rew over 11 years ago in reply to wallarug
    I just put a model B next to a model B+. By inspecting the B I found R36 and R37 as the probable bypass resistors. I checked the scematics, and that is correct. No such "suspiciously vacant" spots can be found on the B+.
    i.e. by disabeling the USB chip on the B+ you'll lose USB functionality. Depending on what you're doing that might be acceptable. Say if you launch your system with a camera on a high altitude balloon to take pictures and video with the camera module. And you're just going to write them onto the SD card with no other IO (or if any on the GPIO pins) then if you DO need the extra RAM, but taking the extra power is "expensive", so this might be an option....
    If sony can solder those BGA chips onto eachother and onto a board, so it is physically possible. People are reballing and resoldering GPU chips on laptops or XBOX consoles. So I'd say the technology is accessable for hackers....
  • Problemchild
    Problemchild over 11 years ago in reply to wallarug
    I may go as far as been a pedant and say it isn't impossible just a totally impractical Ball Ache(tm) of a thing to do that if you were to do this would mean you would have  both the rework kit and the practiced skills to do it and wouldn't be on the thread...Except to crow about it maybe image
    Agreed the A+ is what it is unless they decide to do an A++ a C or what ever they want to do next!
  • johnbeetem
    johnbeetem over 11 years ago in reply to rew
    If you have the right hot air tool, you could remove the LAN9514 and jumper between its USB pins.  But it's a QFN with a large thermal pad, so it's hard to unsolder without damaging the board.
