Raspberry Pi Forum Raspberry Pi, a low cost development board or suitable production use
  • Replies 12 replies
  • Subscribers 680 subscribers
  • Views 997 views
I am currently looking at using the raspberry pi B+ in a business environment. The idea is to have 50 of these connected to LED screens repeating a series of messages for 10-17 hours per day. They will be on every day and store the messages in MP4 format on the SD card. They will be updated every two weeks buy inserting a USB stick with new information that gets automatically transferredacross. (ethernet cable if we advance).
The pi has had all unused items removed and is not overclocked.
There are a lot of people in the business that like this idea however i am getting some who say the Raspberry is a low cost development board that can't cope; and will cost more compared to a custom built device. ( i have had the pilot running for 11 months no issues)
This is a general discussion as to people views on using a development board in this way as i never have before, and if anyone has done something similar.
I think this will work and the raspberry can take the challenge.
  • gadget.iom
    gadget.iom over 11 years ago
    Is this an advertising deployment?
  • johnbeetem
    johnbeetem over 11 years ago
    If you don't need wired Ethernet, you could probably do it with a Model A+, which lists for US$20.  It would be hard for a custom-built device to compete with that.
    Former Member over 11 years ago in reply to gadget.iom
    No! stricly internal comunications and performance updates per area!
    Former Member over 11 years ago in reply to johnbeetem
    I have tested the model A+ used 0.0009 (B+ at 0.001) KWH and works great however lack of ethernet could cause a problem in a few updates. However i brought one for each of my kids.
  • gadget.iom
    gadget.iom over 11 years ago in reply to Former Member
    Ahh. Have made a similar thing (only one off so far) for my workplace.
    With the limited quantity required vs the ability to update/improve the design as needed, the RPi should be fine image
  • gadget.iom
    Another consideration to make could be the Compute Module. Though not yet available, the pricing may be lower than the standard boards, and with onboard Flash and built-in HDMI capabilities you could make a simple breakout PCB to interface with your displays.
  • Problemchild
    Problemchild over 11 years ago in reply to gadget.iom
    The Compute module is more expensive and requires a custom board to be made to carry it so unless you have a very specific requirement it will be more of a PITA than a normal cheap B+. The general idea is sound though to minimize the extra connectors but you could just desolder those at a lower cost/hassle.
  • Problemchild
    you need to describe what you are doing with the MP4 videos.
    I think you will need the buy me now codec from the RPF to play them using the accelerator unless I've missed out on something !
  • Problemchild
    That aside the RPi should be more and capable for this . BTW we can do you some custom cases for the PI(s) to attaché to the monitor's VESA mount if you are interested..All sorts of fancy colours and stuff image
  • gadget.iom
    gadget.iom over 11 years ago in reply to Problemchild
    If they are more expensive, then you are quite correct. I just couldn't find a price without the development kit attached. image
