Following multiple tests I have noticedthat the standard CHIPKIT Serial lib doesn't work with PI: nothing is displayed on console :dev/ttyS0
But it works fine with the lib Serial1
Eric
Eric
You are right. It seems the RPI breakout is not attached to the RPI pins on the bottom. Serial.Println defaults to the serial 0 which must be connected to the RPI. However since the pins are not accessible when the CHipKit Pi is plugged in, there is no way to use the serial port on the Pi.
