Raspberry Pi Forum Kernel as .deb package
  • Subscribers 687 subscribers
  • Views 1123 views
timg73
timg73 over 11 years ago
Whilst compiling the Cirrus 3.12 kernel I discovered that it's rather simple to make a .deb package.  This offers an easy way to get the Cirrus driver without downloading a huge file and re-imaging your filesystem.  I'm not an expert at these things, but I've been using the package for a week or so and it seems to work well for me.  Anyway, if there's any interest I'll upload it somewhere (here?)
    Anything that has the potential to make it easier to set up this card more flexibly is surely of interest. Please do upload or post a link.
  • timg73
    timg73 over 11 years ago in reply to Former Member
    Here's the kernel .deb package.  This is kernel 3.12.33 from https://github.com/CirrusLogic/rpi-linux, compiled and tested under Raspbian 2014-12-24 with the default configuration file supplied by Cirrus Logic.
    To install:
    sudo dpkg -i linux-image-3.12.33cirrus_3.12.33cirrus-1_armhf.deb # install package
    sudo mv /boot/vmlinuz-3.12.33cirrus /boot/kernel_new.img         # rename kernel
    sudo rm /boot/*3.12.33cirrus                                     # delete superfluous files
    and edit /boot/config.txt to use the new kernel:
    # Use new kernel:
    kernel=kernel_new.img
    linux-image-3.12.33cirrus_3.12.33cirrus-1_armhf.deb.zip
  • cstanton
    cstanton over 11 years ago
    I've always been interested, how do you make a deb package?
    Former Member over 11 years ago in reply to timg73
    Tim, that's tremendous. Thank you so much. As I've said in a previous post, I'm very green still with Linux, despite having used Ubuntu for years now. So please forgive what may seem some pretty dumb questions! Am I correct in thinking, from what you said in your initial post, that in theory it should be possible to install your deb package into any existing Linux based distribution running on the RpiB+ (eg OpenELEC, Runeaudio, Rasbian) to enable them to make use of the card? Could you add an additional line or two at the beginning of your instructions to cover getting the deb package on to the Pi ready to install (eg download to another device then copy and paste - in which case where to? Or use apt-get from the Pi.....?) Again, many thanks for your contribution on this.
    Nick
  • timg73
    Hi Nick,
    It doesn't matter where you put the .deb file.  The following will download it:
    wget "http://www.element14.com/community/servlet/JiveServlet/download/140283-165536/linux-image-3.12.33cirrus_3.12.33cirrus-1_armhf.deb.zip"
    This message board has automatically zipped the file (even though Debian packages are already compressed), so unzip it before installing:
    unzip linux-image-3.12.33cirrus_3.12.33cirrus-1_armhf.deb.zip
    After installation you can delete the .deb file if you want.  The kernel was compiled for Rasbian, and may or may not work with other distributions.  Let us know if you try it.
    Hi Tim,
    The same kernel is now available with realtime capabilities (e.g. for live music performance) and support for the older Wolfson card and more up-to-date Cirrus Cards.
    Cirrus cards haven't been tested yet with this kernel 'cause I don't own one :-(
    Only tested with Wolfson audio card. Here it works fine. Instructions how to install and download can be found here ->
    https://blog.georgmill.de/2015/02/18/update-for-wolfson-audio-card-on-raspberry-pi/
    Have fun.
