Raspberry Pi Forum Has anyone built a "MineFrame" already?
  • Replies 9 replies
  • Subscribers 678 subscribers
  • Views 688 views
  • mineframe
  • pi
iambryan
iambryan over 10 years ago
Hey all,
I was thinking as a great Father/Son project we could build a MineFrame consisting of multiple Raspberry Pi 2s and I was hoping to pick the brains of any folks that have built anything similar in the past with any of the previous "Pi"s
TIA
  • cstanton
    cstanton over 10 years ago
    Isn't MineFrame just a minecraft server?
  • iambryan
    iambryan over 10 years ago in reply to cstanton
    I was thinking of building a small cluster of pi's
  • clem57
    clem57 over 10 years ago
    Here is a good use of a cluster of Pi's @http://raspberrywebserver.com/raspberrypicluster/raspberry-pi-cluster.html
  • Problemchild
    Problemchild over 10 years ago
    There's absolutely no Practical reason to produce a Cluster from RPIs as they are not powerful enough to warrant the overhead you would be better off buying a PC.
    The whole point of making the Cluster is merely to learn how such clusters go together and play with the software, so from an educational point of view it's worth while.
    If educating yourself is where you are going then this is  a good idea I'm all for this!!
    BTW you can create several VMs on a PC and do the same thing rather than buy new HW or even mix real and VMs together and do all sorts. Just bare in mind that an RPI does not bring enough power with it to be truly practical .
  • iambryan
    iambryan over 10 years ago in reply to clem57
    Nice, that is definitely along the lines of what I'd like to do.
  • iambryan
    iambryan over 10 years ago in reply to Problemchild
    It's for the hands on aspect for my Son and I. VMs could absolutely fit the
    build (and I have run test scenarios via VM in the past), but this is all
    about being able to also "physically" play around with the technology
    On Wed, Feb 4, 2015 at 11:04 AM, Problemchild <messages@element14.com>
  • Problemchild
    Problemchild over 10 years ago in reply to iambryan
    As an educational device and demonstrator the RPI is great.
    Please take some photos and show us all what you have done
  • packetgeek
    packetgeek over 10 years ago in reply to iambryan
    Yep, definitely has a BIC and BIT factors. Good luck!
    -Tim
    BIC = Because I Can // BIT = Because It's There
  • iambryan
    iambryan over 10 years ago in reply to packetgeek
    Definitely, Thanks image
